Stupid 02 Sensor Question :X
I got quoted $90 for rear o2 sensor, it's a bitch and throwing two codes 0036 and 0037, doesn't affect performance just annoying ungodly yellow light on the dash. They are both indeed different sensors.
Upstream is pre-cat and what the ecu uses to read afr, downstream is after cat and just reads cat efficiency Sp? The op said upstream in 1st post, it will prob be expensive as lnf's have wideband
