Supercharged 2.2
Supercharged 2.2
This is a monumental request for any 2.2 or 2.0 owners, and I would greatly appreciate everyones help. (yellowshowbalt should have exactly what im looking for if he sees this thread) I need a complete list of everything I need to supercharge and intercool my 2.2l. I already have many of the required parts, almost all of them in fact, and am mainly concerned with making sure i have all the correct hoses
here's what i got
M62 Supercharger w/3.4" (custom) and 3.0" (ZZP) pulleys, belt and throttle body, intake manifold with intercooler, Mustang Cobra heat exchanger w/ new BWoody mounting bracket, new intercooler pump, new fluid reservoir, (4) 42lb/hr fuel injectors w/ wiring harness, both idler/tensioner pulleys, new SS/SC washer fluid reservoir, new factory hoses, SS/SC air intake box, along with many miscellaneous bolts and washers and hoses....
also, ive been hearing it wont fit with the stock alternator, and i need the ss s/c alternator...is there any truth to this?
here's what i got
i believe the build guide has the stock internals tested to 250hp not sure what the breaking point is. They do recomend replacing the factory rods and pistons if you want to go over 300hp and thats not 300 at the wheels that 300 at the crank. If you use the internals that i used your engine will be rated to handle 500hp at the crank. Our factory crank is good to 500hp according to the build guide and they have had it working on a 600hp aplication but they didnt say if the crank broke or not at that point.
