Supercharged 2.2
thanks for the GL posts guys, its good knowing ill be helping out other people who may want to do the same thing
edit: i just checked the garrett turbo kit, and they dont replace the MAP sensor. is this suggesting the stock sensor is adequate?
in addition to the abve unanswered question....and this is mostly aimed as sway:
do you need a AEM UEGO wideband? or will any wideband do? all my gauges are autometer ultra-lite gauges, and i'd prefer to have an ultra-lite wideband as well. is this possible?
the part numbers refer to GM part numbers
SUPERCHARGER PARTS LIST
Part Description Part Number
Supercharger Kit 1780003
Clamp - Fuel Pressure Regulator Hose-Intake Manifold End 10028454
Hose, Brake Booster 10358940
Nut - U-Nut Oil Level Indicator Tube Support 11507067
Nut - U-Nut Radiator Hose Support 11507067
Clamp - Coolant Hose Cap 11516226
Bolt/Screw - Intake Manifold Bracket-to-Engine Block 11516342
Bolt/Screw - Intake Manifold Bracket-to-Intake Manifold 11516506
Nut - Intake Manifold 11516076
Bolt/Screw - Radiator Hose Support 11516757
Bolt/Screw - Drive Belt Idler Pulley Bracket 11518048
Bolt/Screw - Generator Relocation Bracket 11518051
Bolt/Screw - Intake Manifold 11518062
Nut - Intake Manifold-to-Head 11518532
Bolt/Screw - Generator Relocation Bracket 11589134
Bolt/Screw - Drive Belt Tensioner 11589147
Bolt/Screw - S/C TO Intake Manifold 11589214
Bolt/Screw - Oil Level Indicator Tube 11589299
Bolt/Screw - Drive Belt Tensioner 11589312
Pin, Connector Female 12048074
Connector Pin Seals 12048087
Lock-Connector - IAC Connector 12052634
IAT Connector Replacement 12052641
Map Connector Replacement 12110293
Zip Tie 12355066
Connector - PCV Tube 12581198
Tensioner Assembly - Drive Belt 12583180
Supercharger Assembly 12584331
Vacuum Hose - Fuel Pressure Regulator 12584337
Gasket - Supercharger Outlet 12584342
Manifold Assembly Intake 12584348
Gasket - Intake Manifold 12584359
Bracket Assembly - Drive Belt Idler Pulley 12584364
Bracket - Generator Relocation 12584365
Tube Assembly - Intake Manifold-to-Fuel Regulator (LSJ Purge Valve Hose) 12584369
Brace - Intake Manifold 12586632
n GM SPORT COMPACT Performance Build Book 39
PARTS LIST
Adapter - Throttle Body 12590814
Belt - Accessory Drive 12590815
Wire Assembly - Map Sensor 12590818
Data File PCM Engine Calibration 12590819
Data File - PCM Engine Calibration 12590820
Stud - Intake Manifold 12590821
Stud - Intake Manifold 12590822
Bolt/Screw - Throttle Body Adapter (M6 X 20 mm Socket Head Cap Screw) 12593676
Washer - 17 mm OD For a M8 Bolt x 4 mm Thick 12593677
Sticker, Carb E/O 12593900
Template - Intake Manifold Gasket Cut Out 12593902
Instruction Cd 12593903
Injector Assembly Fuel 12593904
Plug, Map Sensor 12593906
Gasket - Throttle Body Adapter Plate (O-Ring) 12593905
Template - Dip Stick Tube Support Bracket 12593907
Support - Radiator Hose 12594613
Cap Assembly - Cool Hose 15544596
Cable Assembly - Cruise Control 22688111
Hose Assembly - Radiator Inlet 22718761
Vacuum Fitting - Waste Gate 24507839
Air Duct 24575436
Premium Fuel Decal 25602518
cant forget the premium fuel decal
Zip Tie 12355066
PARTS LIST
Air Duct 24575436
#41
and how are u going to gain 110hp by just dropping a supercharger on a stock 2.2l??
#42
#45
leave it....its almost the same as a ss s/c, ill just have to retard ignition timing a bit more than they do
28 stickers actually...i have low efficiency stickers...
#46
Ohhh thanks man, now i get it, no wonder why those 2.2l are soo ******* fast, i totally forgot about the hp/tq gain that the stickers give to those 2.2
#47
hunterkiller. just ignore the nay sayers, they are just wasting your time.
Get to it, supercharge that **** and pave the way for newbies like myself to learn from your trial and errors(mostly trials i hope).
You dont got time to play forum tag with some trollers, we need progress ASAP, and youre the man nominated for the job.
You have the weight of the entire 2.2l auto world behind you, we believe in you.
LOL!
LOL!
#50
