Supercharged 2.2
Old 09-30-2007, 05:29 AM
  #51
Smitty1017's Avatar
How do you plan on tuning the TRANNY?
very curious. not in a sarcastic way either.
Old 09-30-2007, 05:54 AM
  #52
HunterKiller89's Avatar
i dont really....B&M shiftplus will firm up the shifts under part throttle conditions to not see any clutch slip, and WOT is already set, with the B&M there just making it even stronger
not the best method...but i see it not quite as a band aid, but as a giant medically wrapped bandage to a moderate cut....there will be some premature wear until i can get the tranny tuned, but nothing too bad, especially if i limit the number of hgh boost non WOT shifts the car makes
Old 09-30-2007, 07:11 PM
  #53
Smitty1017's Avatar
Definatly let me know how that goes. I heard from more than one guy that b&m wont work. I dont think tey've tested it, but then again I dont see why it would throw a fault.....
Old 09-30-2007, 07:44 PM
  #54
Delta2.2's Avatar
hey hunter, just thought id chime in and let u know that HPT DOES support our auto trannys. they dont have PCM tuning but the DO have our TCM tuneing cracked. so if ur questioning the tranny HPT got us covered for that at least......to bad not for the rest, and dont count on the rest happeneing ever
Old 09-30-2007, 07:45 PM
  #55
HackAbuse's Avatar
The B&M doesn't work?
Man, I must be on drugs then...
Old 09-30-2007, 07:49 PM
  #56
i know its supported, but i dont think i can flash it....similar t the 07 2.2 ecu....the ecu itself is already supported by HPT, but they need to do something so you can flash it through the cobalt....
ill do a little research into it
i think he meant it doesnt work as a way to tune transmissions under higher HP. hack
Old 09-30-2007, 07:52 PM
  #57
HackAbuse's Avatar
The tranny will be fine, these things are rated for 325lb/ft of torque, it's right in the GM database. I posted a link a few posts back
Old 09-30-2007, 07:59 PM
  #58
mechanically yes, but you need to tune the tranny to shift under 220hp instead of 130hp, or else you'll get clutch slip
we pretty much said the following
"you need to tune your engine to keep a safe AFR ratio
"the engines fine, its rated at 300hp"
see what i mean?
Old 09-30-2007, 08:22 PM
  #59
Smitty1017's Avatar
Yeah i was talking about clutch slip. I actually suggested the b&m as a way to get around the auto tranny problem with F/I awhile ago, with some disappointing answers (i want to go turbo this spring) and yeah, half cent could probly explain the technical answer better than I could. But on a side note, none of them have ever actually tryed any of this, so it could all be wrong, and it could work perfect for you. like I said, keep me posted for sure. When do you plan on hooking this all up?
Old 09-30-2007, 08:39 PM
  #60
Delta2.2's Avatar
what do u mean by "i dont think i can flash it"
Old 09-30-2007, 10:41 PM
  #61
Smitty1017's Avatar
I believe he means theres not products availible/place he can go to do it
Old 09-30-2007, 11:19 PM
  #62
RollOver360's Avatar
U have peaked my interest...
Old 10-01-2007, 04:26 AM
  #63
...i explain what i mean in the sentences following the one you quoted.
you know how the 07 2.2's arent supported by HPT yet? you know how the ECM in the 07 2.2's IS supported? i think its the same thing with the TCM
its all on an ASAP status...first thing i gotta do is actually go buy the AEM F/IC which i hope to do in the first half of this week
Old 10-01-2007, 05:46 AM
  #64
Smitty1017's Avatar
nice +rep for being the ginea pig i thought I was gonna end up being
Old 10-01-2007, 06:00 AM
  #65
Original Hayden Fanatic
REIGN SS's Avatar
Originally Posted by kawasakizx6rr
and how are u going to gain 110hp by just dropping a supercharger on a stock 2.2l??
its call displacement! Same if i SC my 2.4 w/ a stock pulley, it would probably pull on a ST2 2.0 cobalt. The stock 2.0 motor only(no sc) only puts down ~130hp. The stock 2.2 puts down about the same (~130hp), & with the extra displacment this could easily hit the 215-220 mark on the LS...
btw +rep for doing it proper!!
Old 10-01-2007, 09:47 AM
  #66
WunSick's Avatar
get to work, im tired of waiting next to the computer watching this thread living off mountain dew and cheetos. haha just kidding, good luck man, im going to be watching this.
Old 10-02-2007, 07:40 AM
  #67
danielje's Avatar
This is all very intense and interesting, Hunterkiller could break new grounds for all of us in the 2.2l world.
Mad props to you man, I hope everything goes smoothly and nothing breaks on you.*knocks on wood*
If you succeed you can bet alot of money that alot of other people will start trying the same things to get similar results, it would be funny as heck to see someone with a 2.2l auto, pop the hood and a big super charger is sitting on the throttle body assembly.
Definitely keep us all posted as much as possible about your progress or lack of.
This should be stickied or something.
Old 10-02-2007, 09:44 PM
  #68
Ordered the AEM FIC and the UEGO wideband today, brought the total cost of the project thus far to $2k exactly. Im expecting to spend another grand on installing the F/IC and buying a header/downpipe combo with an extra bung for the wideband
Old 10-03-2007, 04:22 PM
  #69
JMH
JMH's Avatar
[QUOTE=HunterKiller89;1501451]102hp, and its simple really....especially since i have a 3.0" pulley in addition to a 3.34" pulley...so its really just my choice
leave it....its almost the same as a ss s/c, ill just have to retard ignition timing a bit more than they do
Fair enough, I was just curious. Hope it works out.
Old 10-17-2007, 01:14 AM
  #70
Build update: i got a set of ZZP midlength headers/DP /w ceramic coating, and i picked up my AEM F/IC and AEM UEGO. None of it is installed yet however, but i do have a tune i made so my 2.2 can run the 42lb injectors like stock.
just keepin you guys up to par
Old 10-17-2007, 04:32 AM
  #71
Smitty1017's Avatar
I swear if it turns out well for you and you say "yeah the tranny is shifting great with the shiftplus!" Im gonna run around my house naked and wank off to your picture on my deck so the neighbors can see all while yelling your screen name "
Old 10-17-2007, 10:30 AM
  #72
elecblue06's Avatar
thats SOOOOOO gay but good luck man i hope it works
Old 10-17-2007, 11:52 PM
  #73
this seriously made me crack up! im repping you for that one!
(its still a little creepy too, btw)
Old 10-23-2007, 02:03 AM
  #74
AMTCobalt's Avatar
how is the progress
Old 10-24-2007, 07:51 PM
  #75
none made so far. i caught pneumonia, and am just now getting over it after a couple shots and prescription drugs. also sw4y is having his own delays and he's providing me with the wiring diagram for the FIC, so i cant do much until he finishes that
Quick Reply: Supercharged 2.2
