Supercharged-Swapping to LSJ 6-rib belt
Old 04-18-2016 | 05:31 PM
jdbaugh1's Avatar
I posted this over in the L61 forums because that is the engine I have but I didn't receive much input so I figured I would see if I can get some answers here in general cobalt.
The main things I am trying to figure out for sure is if the LSJ harmonic balancer will fit on my 2006 L61 engine. Ultimately my plan is to install an ATI super damper but I really just want the standard size pulley. I don't understand why it is only available in overdrive or under-drive.
So is there a 6-rib ATI damper for the L61 engine or do I buy the balancer made for the LSJ engine?
I was also wondering if I need to swap to the LSJ AC compressor or if you can swap the pulley from the LSJ compressor and install it onto L61 compressor. What other parts may I need to do this?
So far I have collected
-LSJ alternator
-LSJ belt tensioner assembly with bracket
-LSJ idler pulley
Unless I am mistaken the only remaining components I need are
-LSJ AC compressor or pulley???
-LSJ ATI harmonic balancer???
If you have experience with this subject your feedback will be greatly appreciated.
Picture of the LSJ belt components I have acquired so far.
Old 04-25-2016 | 11:51 AM
jdbaugh1's Avatar
Anyone?
Old 04-25-2016 | 01:41 PM
ItalianJoe1's Avatar
The L61 pulley is also specd only for over or underdrive?
Old 04-25-2016 | 04:23 PM
advise's Avatar
ecotec covers are the same no reason you cant use an lsj crank pulley
Old 04-25-2016 | 04:46 PM
jdbaugh1's Avatar
My two main questions are:
-What harmonic balancer do I buy for the L61 engine? Are all Cobalt Ecotec's crank pulleys interchangeable? Does ATI provide a STOCK SIZE pulley at all?
-Will the pulley from an LSJ AC compressor swap onto an L61 AC compressor? If not, is the LSJ compressor plug and play if I were to swap complete compressors?
SSxTc0825
11-14-2020 02:05 PM
layne989
03-26-2016 07:54 PM
thewafflesareburnt
03-24-2016 12:30 PM
Steven Rainwater
03-21-2016 02:47 PM
Quick Reply: Supercharged-Swapping to LSJ 6-rib belt
