Tailpipe removal
Originally Posted by limptera13
Has anyone done or know of it can be done - remove the tailpipe in the driveway. Jack up pretty high..... With proper safety precautions obviously
1 to 2 feet off the ground? why so high. I lifted mine a few inches put it on jack stands, crawled under with a socket, breaker bar, and a ratchet and pulled mine out. I had to cut it with a sawzall just before the rear beam to get the exhaust out. Literally took less then 15 minutes, and about 15 to install the new catback.....
it doesn't have to go that high at all. Basically enough to crawl under and unbolt the exhaust. You will need to cut the exhaust just before the rear beam and wiggle it out. Very simple job. Get to it!
if you don't wan't to cut you have have lift the back high enough to lower the rear beam by disconnecting the rear shocks. I have attempted to do it this way, but was unsuccessful. I could not get the exhaust out without cutting. I honestly don't think there is enough room to get out in one piece with the car jacked up and not on a lift. Maybe someone else has had better luck then I have trying to get it out in one piece.
GeforceXtreme
12-01-2015 01:29 PM
