teo4h turbos
teo4h turbos
hey i just got 2 teo4h turbos off of 2.5 dodge caravan and other of a new yorker and they r in great shape i payed 50 bucks for both 25 each at the local pullapart. i now they are a little small but they can produce up to 250hp so i dont now what to put them on. but thats my find of the day i payed 1 dollar to get in then i went looking in the cars to see what i could find and bingo you never know when you need to turbo something. lol any ideas. ps would u think they r too small for a 2.2 cobalt or they would work best with a stock 2.2 and handle future mods too. pss i now there is still probs with tuning on the e61 computer
Turbo a yard tracter. I always wanted to do that just run the carb real rich. and get a small oil pump or some kind of pump to run oil through the turbo. Make shure its a brigs and straton flat head they have low cylender compression.
Now make the turbo work on it and run good at the top end. Then after you get that out the way. If the tractor is belt driven the rear pully over the diff on the main belt take that off and get a smaller one and get a belt to fit, It had a old craftsmen tractor that did 64MPH just buy takeing the 7 inch rear pully and making it 2 inch it was awsome I had to shift the tractor like a car because it would stall.
I also had a off road go cart with a 1984 Honda 750r motor on it that went faster then I dared take it but I had it to 107 MPH but thats in a go cart 2 inches off the ground. And to answer what your thinking I have a universal speedometer that works on any thing with wheels.
yes its always fun to try to use turbos on a engine that doesent come with them to see what kind of power you can make with it. it all about the challenge
well im going to go get the other 2 that i found i hope there in good shape thats a total of 4 teo4h turbos. i wander if 1 turbo for 2 cylinders on a v8 would work its just a thalt.
well i pulled 1 and the other wazs junk full of rust and sandy grit so i think its safe to say id no good. but the other i got was a garett a/r .42 and its in grate shape no play and spins smooth. so now i have 3 i wonder whati should put them on
