Traction!! Cobalt v. SRT4
First of all this isnt a war story.
Just think about how alot of people complain about there traction and how bad it is when most of the time there are is under 250whp. How the hell can an SRT4 with stg 3 at like 350whp have pretty decent traction. What do they have that the cobalt doesn't. besides obviously the tires what else? Does buying wider rims make that much of a differece either?
SS = no traction instant boost and wheel hopping goodness all the way to middle of 2nd. woo hoo!
Rattlesnake Race Shop
I had an srt-4 and everyone i know had traction problems... basically we feather the clutch(AKA Burn the clutch alittle) at the line and then when you feel traction... dump the clutch the rest of the way
HP tuner works.I have first set up at 60% then all hell breaks lose in second.I think I need to drop it some more,I still get a little wheel hop at about 5k. I am trying not to burn up my clutch yet. I will let you guys know what % works the best.
^^wow, i might have to come down to you sometime and have your buddies tune my car! assuming yours doesnt blow up in the next year.
wow much did he charge you? i see all the prices, but which one?
I put my boost in first to 50%. It is nice to not do a burn out all the time. I need to raise the boost to 100% after 5k Rpm's. It does help alot to limit the boost in first.
The Flash and one Hour dyno time $250.00.
so getting a 2.8 with 60 lbers and you think you can press the 310 whp mark?
Originally Posted by BaltM62
i doubt he can. i would suggest going to another dyno and seeing if the numbers are compareable because 260 stock probobly isnt right. there are things they can do to the dyno to inflate the numbers..
Originally Posted by hatrickstu
ok so this guy dynoed 260 with a tune on a stock setup, sweet. got any track times
hah whats traction? mines just at 300 a lil over...and if i am in 2nd gear and just hit the gas and the tires just break loose...hell i even spin slicks at the track..
