Trickle Charger
Old 01-05-2013 | 05:53 PM
EMAC X 61's Avatar
Trickle Charger
Am i able to hook a trickle charger on the post under the hood? i am unable to get to my battery due to the sub enclosure that i have. just wondering thanks!! i have an 09 ss/tc if that matters
Old 01-05-2013 | 06:20 PM
StevoElSupremo's Avatar
I've had an issue with that charging post, I accidentally killed my batter twice, and when trying to boost that post didn't work, and it took a charger.. DAYS (not literally) to re charge my batter from that post...
yet when I did it direct to the batter (jumpers) it started right up, and charged in a few hours direct to the battery as well
Old 01-05-2013 | 07:17 PM
insylem's Avatar
Its best to do direction on the battery, but I don't see why it woudln't work to recharge it from that post. The alternator does when you drive it.
Old 01-05-2013 | 07:45 PM
kzak104's Avatar
yes u can. ive charged a cobalt from it
Old 01-05-2013 | 07:59 PM
EMAC X 61's Avatar
okay i just want to charge the battery during the winter months while its sitting in the garage so the battery doesnt go bad and i have a trickle charger so just making it safe that its okay to do
Old 01-05-2013 | 08:08 PM
ah, well I guess if you're doing it over long periods it would be best to do it from the post, I always thought you removed the battery when storing a car... no?
Old 01-05-2013 | 08:18 PM
Omnigear's Avatar
its a manual.... push pop it to 2nd gear profit
Old 01-05-2013 | 08:35 PM
EMAC X 61's Avatar
i would love to take my battery out and charge it that way, but i got a custom sub enclosure that takes up my entire truck and i would have to take it somewhere to be taken apart so i can get to the battery lol
Old 01-05-2013 | 08:37 PM
lol right^ missed the custom sub stuff
Old 01-05-2013 | 08:42 PM
EMAC X 61's Avatar
yeah thats the only problem, and the battery is already dead, so i am just going to trickle charge it off the posts under the hood until winter is over!!!!!!
Old 01-05-2013 | 10:37 PM
insylem's Avatar
your best bet for that is to completly REMOVE the battery. DO NOT place it on any cement. The cement and the battery are chemical oppsite and it can neutralise the acid in the battery.
Best to keep the battery someplace warm too. Maybe the office in your house?
Old 01-05-2013 | 10:42 PM
insylem's Avatar
Also do not place it near NiCad batteries for the same reason
Old 01-05-2013 | 10:48 PM
BLAZIN07SS's Avatar
I'm too JDM for you
This was true when batteries were made from wood. No longer the truth.
Old 01-05-2013 | 11:33 PM
SSSnoop's Avatar
Too much torment on this board - give me headache......
I bought a solar charger, and I've charged off that post no prob. If you're in an area that gets a decent amount of sun, this can be an easy and free way of keeping your batt charged.
Otherwise, a trickle charger will charge just fine off that post. One caveat, however; I would be careful of the "de-sulfating" trickle chargers if you're using them - they have an intermittent high voltage cycling that is supposed to de-sulfate a battery with bad charge; if you have one, it can do bad things to your electronics unless you disconnect the battery from the car, unless you disable it. I have a duracell 2A/trickle charger that I've used on all my cars which doesn't de-sulfate a battery. I also have a "battery tender" which de-sulfates, and I NEVER use it on any battery connected to a vehicle electronics, for the reason that it can do cruel things to any electronics connected to that battery......
Old 01-06-2013 | 12:03 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Yep. All desulfating is, is a controlled overcharge. Also known as equalization. Voltage can go as high as 15.5-16 volts. Definitely not recommended for it to be connected to the vehicle.
Old 01-06-2013 | 09:36 AM
Aleksey's Avatar
Should be fine, though I DO suggest to go directly to battery with trickle chargers.
Old 01-06-2013 | 03:10 PM
insylem's Avatar
Um, Don't think batteries ever were made of wood...
Clay pots on the other hand...
Baghdad Battery - Wikipedia, the free encyclopedia
Old 01-06-2013 | 03:18 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Batteries used to be made from a wood case and glass. When you would put the battery on the floor, it would pick up the moisture, the wood would swell and crack the glass causing acid to leak out
Old 01-06-2013 | 03:45 PM
Powell Race Parts's Avatar
^^^ batteries are Josh's business. Hard to find a fault with anything he says in this respect, he is the source!
Old 01-06-2013 | 03:51 PM
EMAC X 61's Avatar
We'll I have a battery tender trickle charger hooked up to the post under the hood. So should I be okay to leave it hooked up ? Don't want to wreck something on my car
Old 01-06-2013 | 04:39 PM
serega12's Avatar
So whoever made the custom enclosure wasn't aware of the battery/spare being below the trunk carpet? You'll have to replace the battery eventually.
Old 01-06-2013 | 04:42 PM
EMAC X 61's Avatar
Yeah we'll they have to take the enclosure out come this spring to put my coilovers in. But no didn't think it through all the way lol.
Old 01-06-2013 | 07:04 PM
you will be fine with a decent trickle charger hooked up under the hood, (use a decent ground,) that turns off and on periodically. Ideal.
Old 01-06-2013 | 08:40 PM
05RLS2's Avatar
It is perfectly fine. I use a Battery Tender with the quick connect that is installed under the 12v post, been OK for me
Old 01-06-2013 | 09:18 PM
SSSnoop's Avatar
I noticed I didn't exactly write clearly on my other post (brandy may have had a role in that....) I don't necessarily think its a problem if you connect a desulphating charger directly onto the battery at the terminals while its in the car - after all I'm pretty sure Deltran went through a lot of pains to ensure that their charger wouldn't go all hinkey if its was hooked that way. I would be concerned that the charger algorithm might be affected by the introduced distance/loss by using it on the post - after all it monitors voltage of the battery to determine charge mode, and if you have an introduced voltage loss as a result of that distance, who knows that that thing will decide to do!
hacadacalopolis
10-28-2015 07:09 PM
venum_us_2002
01-10-2006 09:48 AM
jzchev28
08-13-2005 12:01 PM
Impavalier
09-10-2004 03:03 AM
