twin turbo cobalt
Old 12-14-2012, 03:22 AM
  #51
Vander Nars's Avatar
Man **** a twin turbo! In be the first person to go twin supercharged!
Old 12-14-2012, 08:01 AM
  #52
Nfamous60's Avatar
...........smh the **** ppl think of, **** might has well go AWD conversion to, would benefit more.
Old 12-14-2012, 08:56 AM
  #53
Omiotek's Avatar
its not worth the time nor the hassle. with the amount of room you have to work with the size turbos you will be able to stick in there you can get easier with one big one.
Old 12-14-2012, 09:33 AM
  #54
Blinker fluid's Avatar
kangolriot!
Old 12-14-2012, 10:19 AM
  #55
StevoElSupremo's Avatar
I do LOVE the way STS turbo's sound though! so damn loud
Old 12-24-2012, 03:28 PM
  #56
Steviodaddio's Avatar
Try it, just re-fab everything and mount them like the picture above. lol
Old 12-24-2012, 03:49 PM
  #57
EXsoccer1921's Avatar
i'll post what i did in another thread.
"twins just are not necessary. the amount of work you'd have to put in to mount them up vs running a properly sized single turbo just wouldn't be worth it."
"the only way i could see doing twins. they would have to be terribly small. so small that even with both of them, peak power just wouldn't be there. one mounted on the manifold to get most of its spool from cylinders 1 and 2. and the other mounted by the tstat housing getting most of its spool from 3 and 4. compressor housings on the timing chain and trans sides respectively. with the turbine sides in the middle with a shared downpipe connected in a way to prevent the exhaust coming out and flowing directly at the other turbine housing.
and even IF you could get that to work. a single 252 or 256 will still give you a crazy power band with the peak to go with it. in a simple bolt on kit with none of the custom fab work, other than modifying something to your liking, that would come with a twin setup"
Old 12-25-2012, 01:57 AM
  #58
terry11's Avatar
I'm going to have to disagree with you here partly. Only because i've built my fair share of compound turbo setups on diesels and I know how capable they are. I am agreeing with you on the part where 2 turbos up front isn't worth the time/money/fab nightmares, but using one manifold charger 45-50mm, 50 trim and a large remote mounted turbo compounded to the manifold charger would be very efficient.
Properly setup compounds wouldn't push the motor any harder and make more peak power with better spool than a single turbo big enough to make that same peak number.
It's not that hard to route a 60mm gate from before the manifold charger back into the exhaust and remote mount a 66mm (for example) with a scavenge pump for the return line and compound your air charge into the compressor inlet of the 50 trim. Compounds don't just work well on diesels the math is still the same with gas just smaller wheel diameters usually.
But for the average Joe a single bolt on turbo is the way to go. Most don't have the patience or drive to tackle something like that. I've often pondered the idea but i'm still searching for trans reliability.
Old 12-25-2012, 02:07 AM
  #59
but thats not what i'm saying. i'm not saying they don't work. i'm saying they aren't worth it. not on our cars. a single turbo, s252 or s256 just for example. will be a far better time/money/install/power option on our cars vs anything else.
Old 12-25-2012, 02:55 AM
  #60
bykryder83's Avatar
I'm pretty sure exsoccer and myself are on the same page, single larger turbo and proper setup and you'll make good power and save money. Compound turbo setups and twin charge setups are flipping retarded on 4cyl cars and a complete waste of money! Oh and talk about over stressing your engine lol!
Old 12-25-2012, 03:00 AM
  #61
bykryder83's Avatar
These are small displacement 4cyl vehicles we are talking about. IMO supercharging the 2.0 was a terrible idea from the start! Gm took the ecotec from sabb way back when, took the turbo off, slapped a supercharger on and said merica! The lnf is actuall a very old sabb engine design as well.
Back to point, if you twin charge or compound turbo a small displacement 4cyl you are mentally retarded on so many levels with more dollars than sense
Old 12-25-2012, 03:07 AM
  #62
not quite how i had meant it lol... but yeah. i think a proper sized single and a correct a/r for the application will be much better and easier than a compound or twin turbo
Old 12-25-2012, 03:12 AM
  #63
bykryder83's Avatar
Kids these days........
Old 12-25-2012, 03:38 AM
  #64
cluelessk's Avatar
I wonder how hard it is for OP to function daily?
Old 12-26-2012, 08:21 PM
  #65
terry11's Avatar
You must not have read my whole post... So let me clear things up here quick. You're saying compounds are only beneficial to certain sized engines? Or just anything above 4 cylinders?
Are you feeling special because you think you're on the same page as exsoccer? haha One more thing, how do you figure properly built compounds "over stress" your engine?
Again I agreed with this statement. Why everybody is so closed minded on this site, and so quick to shoot down everything they think they know, just because of some bs they read on the internet and not because they have real life experience, is beyond me. I must be flipping retarded Ex
Old 12-27-2012, 01:39 PM
  #66
Nfamous60's Avatar
smmfh
Old 12-27-2012, 03:36 PM
  #67
NICOMAN's Avatar
agreed..most people do exactly that and are just parrots repeating what they heard some guy say in some shop 20 years ago ..alot of it is ignorance and hating..BUT ..in my experience i have to agree with these guys..how many boosted cars have you built? theres always something and it always ends up running more money and w.e. ..part of the game tho ..but now your talking about a setup that will be more fabrication then anything..first off more parts means more places to go wrong..second off all that money your going to dump into fabrication ..u could drop in the engine ..make it a monster and keep that single turbo on high boost and get more power for the same amount of money if not less..i know its cool to be dif and sh** i respect it but sometimes no1s done it for a reason ya kno ..
Old 12-27-2012, 03:44 PM
  #68
ULWizSS's Avatar
Most people cant even apply a single turbo to the ground or run good times with them. And honestly most have no idea how 400hp which is reachable on just one turbo feels on our cars or any car for that matter.
This idea made me laugh really hard and is completely lame and stupid all at the same time.
Stick with a single turbo.
Old 12-28-2012, 03:23 AM
  #69
Nfamous60's Avatar
Old 12-28-2012, 09:42 AM
  #70
sponge14's Avatar
Why does this stupid topic keep coming up, and why do people just refuse to use the search function?
Old 12-28-2012, 10:43 AM
  #71
Jedi Master
Tsbbzm's Avatar
Be sure and post up some pics when/if you do it!!!
Old 12-28-2012, 11:08 AM
  #72
Texas SS's Avatar
Lol oh my
Old 12-29-2012, 08:22 AM
  #73
Aleksey's Avatar
I honestly don't see a point of twin turboing a 4 cylinder... money could be invested into much better **** that will be more stable and put out better results.
in before because racecar
Old 12-30-2012, 12:51 PM
  #74
Crav3's Avatar
Why don't you just make it rear wheel drive.. Put the engine in the rear with Trans.. Wpuld make alot of power just putting the engine I'm the back lol
Old 12-30-2012, 01:25 PM
  #75
Nfamous60's Avatar
^^^ agree
Turbo Johnny
02-21-2019 09:41 AM
09BlkCrusader
09-09-2015 04:47 PM
Rayray2781@gmail.com
09-09-2015 10:40 AM
Josh@ottp
09-08-2015 10:18 AM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: twin turbo cobalt
