Valve cover bolts pattern
Gm doesn't have one for ecotecs. Personally I rotate around the cover skipping every other bolt then come back around and get the ones I passed. Torque spec is 89inlbs
I criss-cross starting from the middle and work my way outwards.
Remember 89inlbs is almost nothing.
FWIW, I just installed an intake plenum spacer on a VQ35, and the torque spec is incredibly low on those two, so low that the maker of the spacer actually recommended using a socket driver (looks like a screwdriver handle) instead of a socket wrench to ensure that you don't over torque it.
Snail_SS (09-08-2015)
