What octane gas for SC'd Cobalt?
Old 03-31-2007, 05:07 PM
an0malous's Avatar
use 93 or 94 if you can find it.
if all you can get is 91, use 91.
if you use less in the ss/sc....your an idiot. plain and simple.
(unless you ONLY city drive, and barely make it above 3krpm, or out of 2nd gear)
Old 03-31-2007, 05:40 PM
IMADreamer's Avatar
As many have said use premium, 91, or 93 which ever is available in your area. If you use less you will get detonation and that's not good for your engine. Plus you spent all this money on the high ends SC version so you might as well use the good stuff to get max performance out of it because if you use 89 or 87 the computer will pull timing and you will lose performance.
Don't bother using higher then premium pump gas though because you aren't tuned for it and you are just throwing money away. There will be people who claim to get kick ass performance out of 100 but it's all in their head because without a tune you can't run the extra timing required to get better horsepower out of the race gas.
There that's the lowdown on gas.
Old 04-01-2007, 02:40 PM
RBC
RBC's Avatar
If someone tells you to use anything lower than 91 otc in this car never listen to any thing they say! 91 otc and up is what they recommend and as mentioned above, it is what the car is tuned for. I stopped using 87 otc after doing my own and other peoples engine rebuilds and seeing what that crap leaves behind. When you tear an engine down you can tell right away what kind of fuel they use and if they change the oil like they are soposed to. I have always have seen better mpg that is enough to make up for the cost and actually save me money.
Old 04-01-2007, 03:17 PM
splitintlss's Avatar
ive always used 91 then i put 87 in one night (when the atm ate my card and i only had so much cash) my car threw a cel the next day it was weird prolly not the gas tho, anyway 91 all the way.
Old 04-01-2007, 03:25 PM
intense_SS's Avatar
i wouldn't use octane gas if i was use...its not really good for our cars and ur not gonna see a very big difference anywayz, so prolly dont do it!!
Old 04-02-2007, 01:34 AM
Schultzay's Avatar
....What???????????
Old 04-02-2007, 01:40 AM
exiged's Avatar
ive considered using 89 in my 2.2.
would that be a waste of money u think?
Old 04-02-2007, 01:45 AM
1gmfanatik's Avatar
93 FTW!!
Exiged...Any higher octane fuel is going to help, but is manufacturer recommended for the SS/SC's because of them being F/I'd..It shouldn't affect you as much with the octane changes, but I have always used at least mid grade in all my rides. The Cobey gets 93 and nothing else though, she spoiled. lol
Old 04-02-2007, 09:23 AM
katie's Avatar
I heard 91 or higher on anything SC or turbo'd. My husband uses 93 in his WRX. He wants me to use 93 in my SC but I like my 91.
Old 04-02-2007, 09:55 AM
bojan's Avatar
91 octane
Old 04-02-2007, 10:39 AM
  #36
barryBlueSS's Avatar
Use 91 or better, we had a couple gas shortages here and I couldn't get 91 and I throw a code everytime I use the lower octane. Put the 91 in and code goes away within 1/4 of a tank. I think with the CAI I run a little lean.
Old 04-02-2007, 10:15 PM
  #37
RBC
RBC's Avatar
If you have access to 93 ditch the 91 you will see benefits as far as power, mpg, and a cleaner engine on the inside.
Old 04-03-2007, 10:15 AM
  #38
Mikey851's Avatar
Damn, I just bought my Cobalt SS/SC; it's an 06' with 6,000 miles on it. The place I bought it from did not have the owners manual (which I plan to get from Chevy asap), so I called the Chevy dealership and they said to use 87 octane. I'm glad I came to this site to check it out.
I actually said, "You're kidding right, a SC'd car takes 87?" and he said yep, the spec is right here in front of me, so I trusted him. I've been running 87 for about a week now, and I'm sure if I switch immediately my car will be fine. As a matter of fact, mine hasn't ever thrown a CEL so I think the ECU has the ability to pull alot of timing if necessary.
That will teach me to trust a Chevy service writer!
Old 04-03-2007, 10:36 AM
  #39
alleycat58's Avatar
Also 91 or higher is recommended on high-compression N/A applications as well.
Old 04-03-2007, 10:46 AM
  #40
portergraph's Avatar
just FYI - you can sign up/register on Chevy's owner website and get a PDF version of the manual...
Old 04-03-2007, 10:47 AM
  #41
Red07SSNA's Avatar
Best thing about this website...useful information! Thanks!
Old 04-03-2007, 10:50 AM
  #42
yellowcobaltss05's Avatar
just use 93 its only a couple extra dollars that will save your engine and its performance
Old 04-03-2007, 10:52 AM
  #43
xxdarkbladexx's Avatar
In the manual i was reading...Several people said that 2.4L should use 91 but the manual says 91+ for the 2.0L and 87+ for the 2.2 i didn't see anything about the 2.4L i guess i didn't read far enough but i've always run 87 and i've never had any problems..In fact i switched to 91 for a month and my gas mileage didn't increase at all and even if it makes a difference powerwise its not enough to be able to tell
dennis69
10-20-2015 04:49 PM
The Rookie24
09-20-2015 04:33 PM
twilson380
09-14-2015 10:52 AM
Highgross89
20
09-11-2015 03:24 PM
jthwjde
09-07-2015 09:24 AM
Quick Reply: What octane gas for SC'd Cobalt?
