Whats under the dash
I have a really badass idea, but someone mentioned that under the dashboard above the radio in the ss/sc. was pretty much empty........ can anyone verify how much space is underthere short of me goin at my car with a dremel lol.
.....mmmm if there really is space under there.......
cut part of the dash a little bigger than the size of a 7" lcd screen. make it so you can push a button and a motor raises the screen attached to the piece of dashboard just like a firebird style headlight..... that would be so badass and discrete as hell....
any thoughts?
any thoughts?
any thoughts?
any thoughts?
...as long as there is space, its not a very complicated process.... just need a motor, some wires, a switch, a few gears, and a little work
**edit** heres a cheesy picture i drew... i swear its cleaner looking in my head!
thats why i was asking how much space i had available... also i have a few other ideas on how to get it to work, but i suck too much at paint to try and figure ot how to draw them lol
The center vent ducts are right there . How intrusive they are , I dont know , but that is where the ducts for the center vents are . You can take the top dash off without removing the entire dash . The top is like a cap . Take the A-pillar trims off , take the header panel off ( the strip that follows the base of the winsheild ) , remove the gauge cluster trim bezel , all the silver bezels , both caps of either side of the dash ......then u should beable to take off the upper dash . From looking in the service manual , its only held on with the same style clips that the silver trims are held on with .
Thats all the info I got . I looked into because I plan on putting something there too , its not a DVD screen though .
**Now that its cold outside ....If u do this , make sure the inside of your car is nice and warm . The clips are buff , and cold plastic crack is alot more prone to crack .
thanks, ill look into disassembling the dash whn i have a little bit of free time!
WHEN i get around to it, ill take pictures and measurements so others can use it.
Yeah, or spend alot of time and money doing a custom paint job that looks really cool and then put PAINT NOZZLES IN YOUR WHEEL WELLS JUST TO SCREW IT UP!!!! GOD I HATE THAT STUPID ASS SHOW.
Oh wow look at me i can spray paint all over the place and rub it around with my Z rated $250 a piece tires woo hoo!!!!
soooo.... the thing that holds our hood open, where can i get those but about 4-6 inches long? something like that would be perfect!!!
1 Post
I dont know if this will help, but here's a breakdown of some of the dash. It dont show the air ducts though. And the picture that shows the air outlet ducts dont show the dash. odd
