Will lt brakes fit ss?
There are 4 lug and 5 lug cobalts both of which have different braking systems at least as far as the rotors go and at that point im 99% sure the pads and calipers are different too. Just make sure you get whats actually recommended for your model. The year matters too for some models.
Thanks ecaulk
Hawk makes great pads
Really anywhere dude, what do you need, pads and rotors? If you want stock replacement stuff, crateenginedepot sells oem at cheaper costs.
Napa sells decent quality
Autozone has good core exchanges
Ottperformace has great deals on great performance packages like ebc and hawk
brake pads have a set of pins on them that come exposed when the pads wear down to the point of needing to be replaced that cause the squeaking sound to warn you to change them before they get to the point that they will start tearing up the surface of your rotors
