2.0 TurboSystem: How would YOU want it?
#251
If you need help verifying people, I'll try to help as much as I can. I'm a military Information Systems Tech.
#252
Normally we show our military ID. Guess if you needed it they could fax a copy of it. Another option that I thought of is that they could send you an email from their military account. Normally members of the services have an email address that is either service or command(where they work) specific. Something like "robert.shoemaker@army.mil".
#253
Yes, that is a great way to confirm since we all have a .mil email for work or the faxing of the ID card. A couple places will do it over the phone just by you asking because we are the only ones that know about them, so we ask!
#254
I found a shoe store that gives 15%....real nice to know. Well, in her case, not mine
#255
im curious of what you guys have done for a idler pulley setup to replace the supercharger with? or did you guys replace the alternator with a different one?
#257
must have missed it cause i skimmed thru the whole thread... o well as long as theres something there doing about it... I was just curious cause they didnt have that in the description of level kits so I was wondering at what level they include it
#258
We will provide guidance on how to implement a very effective solution to our customers. We ditch the entire supercharger belt drive...all of the idlers, brackets, four-foot long two sided belt, ALL of it. There's no need to retain any of it with our approach, and it's an affordable solution too.
#259
Hey Bill, can you post up some pics of the oiling fitting/special part that goes where the drain plug used to reside? There are a lot of people interested in seeing it and how it works. Thanks!
Also, I have to square away a few more little things first, but my order we spoke about should be coming your way before I return from this deployment.
#260
From the sound of this, you are leaving the belt drive revision up to the customer?
Even if it is cheap and simple, clarification of this would be nice. I'm sure a lot of people think that with the $4400 Level V kit, they are getting EVERYTHING needed. At least that is the way the website makes it sound. "...all the way down to the turn-key complete TurboSystem that's a 100% solution."
#261
I thought Level V was a complete turn-key kit?
Of course, with any power adder of this nature, there's always going to be other concerns that may be related to, or are caused to be needed by, the installation of a turbosystem. Some examples include clutches, exhausts, and there's certainly more. We are treating the belt drive mods as one of these, but BONUS! We figured a way to do it that rocks for clean simplicity and ease! And we share this, at no additional charge, with our Customers...but only our Customers. We just don't feel compelled to over-describe it and, in doing so, teach the world how to do it...that's not our duty! Our duty is to our customers, and it would be a dirty trick on them to share for free what they pay darn good money to attain!
Anyone who is buying a system will be hip to what's up, it's easy and very affordable, and a perfect complement to the OEM-quality of the TurboSystem.
#266
#267
Sounds good. Can you post a pic of the oilr return part that screws into where the old drain plug used to reside? There are a lot of people interested in seeing it or at least knowing how it works!
#268
As this oil drain system is currently undergoing patent consideration, we are rather tight-lipped about it too, so no spy pics
#270
#271
It seems to me that the only change they would be doing would be swapping out the alternators since the 2.2 alternator runs in both directions apposed to the 2.0l which only runs in one direction. If that is the case i heard you lose voltage through out the system of the car, so hopefully it's something different. Guess I'll find out when i get my kit.
#272
Hey Bill, what flange does the turbo outlet use? It looks like a standard 3 bolt
2.5" flange that transitions to the 3" V-band. Is that right? Thanks again.
Would this be a pretty accurate piece of my decription as well?
#273
It adds V-band clamp capability to the Mitsu Super turbos we've had such success with over the years. Trick machine work, nice tapered transition to the 3" downpipe
#274
I finally realized I'm going to need to make a custom downpipe for my setup in mind, so that's why I'm asking. I always choose to go the hard route, but it makes me feel so much more accomplished in the long run.
#275
Ok, that looks even better than the pic I posted. Are those available separately as well? And if so how much? PM me if necessary.
However, it does only fit Hahn Mitsubishi Super Turbos. If that's what you have, shoot me a PM and we'll talk details.
