2.0 LSJ Engine: Airbox modification
Old 11-20-2006 | 08:47 PM
  #251
SS_SC_Cobalt's Avatar
Originally Posted by Codyak Supercharged
I just did the mod, same exact filter
the engine light came on as i expected i reved it up after driving a bit in the garage went up to about 4500 then let it down, it stopped at about 2,000 and reved itself up about 3g rpm then went back to idle. It idles fine but i wonder if this is just the computer getting used to the air mod or if it is possilby something else. I did disconnect the - on the battery for a few minutes
thanks
was the motor cold? if so this sounds like normal cold start idle.
Also for the light, make sure you did not overoil the filter, get some CRC Mass Air flow cleaner and clean the maf then see
Old 11-20-2006 | 09:20 PM
  #252
Codyak Supercharged's Avatar
the engine was warm, i had just driven it around testing out the filter (about 7 miles) then checked the revs...the filter came oiled i just put it in....?
Old 11-20-2006 | 09:48 PM
  #253
could be the engine adjusting but check your connections and make sure everything is sealed tight and ready to go.
as for the oil, the filters can be oiled too much, I would def recommend cleaning the maf, I'd bet that you would lose the light go to autozone and make sure it is PO171
Old 11-21-2006 | 01:42 AM
  #254
Talking wow
you were right! the MAF sensor had to be cleaned,
now it drops in rpm correctly
thankyou very much!!!
Old 11-21-2006 | 07:57 AM
  #255
Old 11-21-2006 | 11:31 AM
  #256
Trag's Avatar
How exactly are you guys cleaning the airflow sensor? With an air hose or a liquid spray?
Old 11-21-2006 | 01:31 PM
  #257
Talking
buy a compressed can of electronics cleaner or MAF cleaner
and to be honest air intake cleaner also works and wont harm the sensor
some people lightly use a q tip the only problem is the small hairs from the cotton swab might get stuck....if you do that spray pressured air on it.... make sure its completely dry before you plug it back in``
Old 11-21-2006 | 08:42 PM
  #258
DONT USE A Q TIP!
lol
The CRC MASS Airflow cleaner is best 6 bux!
Old 11-22-2006 | 01:07 AM
  #259
Originally Posted by SS_SC_Cobalt
DONT USE A Q TIP!
lol
ya for the most part your right
but ive red guys on f150 forums evo forums i can go on forever, many people using q tips and havent heared of anyone breaking them yet........but then again it only takes one!
Old 11-22-2006 | 01:16 AM
  #260
CobaltSSilver's Avatar
Did you CEL clear as well? Also there is a PCM update for our cars pertaining to the CEL caused by a CAI.
Old 11-22-2006 | 09:02 AM
  #261
q tips disintegrate easily, go to radio shack and get some compressed electronics swabs if you have to do it that way, but the $6 can will last for the life of the car, couple squirts and it's done
Old 11-28-2006 | 06:45 PM
  #262
smp4488's Avatar
I did this mod last night with a 25$ filter from Autozone. It is awsome and i havent had any cel's yet. I would say i have driven the car about 50 miles from last night and its all good. I did not disconnect the negative battery cable yet but im planning on it. The only thing im not happy with is when i take off first gear is awsome but i shift to second and push it to the floor and the car falls on its face till about 2 grand then takes off. Anyone else had this problem? Im hopeing that disconnecting the negative battery cable will fix this but i doubt it. I haven had a chance to go to the dealarship to get the new flash but from what im reading i should probably go do it soon. Great advice and thanks for the help.
Old 11-28-2006 | 06:51 PM
  #263
D4u2s0t's Avatar
uimmm... how are you getting to under 2,000 rpms in a 1st to 2nd shift?? maybe it's your shifting which is putting your car totally out of it's powerband, not the filter
Old 12-14-2006 | 07:06 PM
  #264
Sizzle06's Avatar
I just recieved my drop in K&N filter part#e0777 and want to do the air box mod,what do i have to do to keep it in place?Or am i going to just have to drill holes in the lid?
Old 12-14-2006 | 10:01 PM
  #265
Asphalt Assault's Avatar
take a 1 inch hole cutter for a door lock and drill carefully planned holes all over leaving good material to maintain some strength. then put the lid back on. I even put holes in the cover. you need the bottom cover to hold the filter in.
Old 12-14-2006 | 11:57 PM
  #266
an0malous's Avatar
DONT USE A Q TIP!
lol
or just by a dryflow filter and avoid all these problems entirely!
Old 12-15-2006 | 08:37 AM
  #267
Wow I have never had a problem (yet..LOL). will have to watch it on re-oiling.
Old 12-17-2006 | 06:44 PM
  #268
Pooch's Avatar
i know this thread is old but i just read the how-to part and noticed teh filter used. the how-to is great, but the filter i would NEVER use. i had on on my 1995 CHev tahoe wit a 6.5L Diesel in it. well after about 5 months with it my truck started to run like crap. after looking at it i found that the metal ring on the inside of the filter came off and sucked into the turbo!!!! it took me months to get a rebuild from the guy i bought the filter from but i did. just to let you all know. i would never use a filter with a metal ring on the inside.( like the one in this how to
Old 12-18-2006 | 06:24 PM
  #269
RollOver360's Avatar
wow I just clicked on the original link to the sound clip, and Tiffany from Big Naturals popped up on my screen.... and I completely forgot about the sound clip. Anyone else get this?
later
Old 12-18-2006 | 06:33 PM
  #270
later
not sure what you got I just tried it and its fine
stop watching ****, lol
as for the turbo diesel, it wold pull a lot more volume of air than we can
the filter was in for 9 mos and never had a problem..
Old 12-21-2006 | 11:03 PM
  #271
pimpnwink's Avatar
still confused
i dont understand how to keep the filter in. What clamp do i have to use it might be simple but i just don't get it lol thanx in advance.
Old 02-01-2007 | 09:34 PM
  #272
JUST_A_RED_BLUR's Avatar
hey i did that **** to mine last summer and i cut the airbox cover just to leave the part wit da maf neway my ***** fucken loud and i dynoed it b4 when i first got the car to see if all the hype was true sayin it pushes more than 205 stock and it did it pushed out 217 and with the airbox mod added 4.5 hp bringin it up to 221 now all i gotta do is dyno it now with the exhaust im expecting another 7-8 HP
Old 02-01-2007 | 11:06 PM
  #273
What exhaust are you going with? I'm curious on dyno numbers for Corsa and GMPP. The magnaflow seem to be consistent, but GMPP are all over the place and I have yet to hear of a Corsa Dyno number.
What were your TQ numbers...is the 4.5 HP gain peak gain or best gain?
If I don't want to mess with the cutting and I want to spend the dosh on the AEM CAI what gains should I expect on a GM stage 2 tuned car? 9HP...less....more.....? Best gain? Peak gain?
Last edited by CobaltSSilver; 02-01-2007 at 11:06 PM. Reason: Automerged Doublepost
Old 02-01-2007 | 11:34 PM
  #274
Pyros777's Avatar
Originally Posted by asyferme
www.autoanything.com
SKU: 2255657
Part#: 21-2110DK
Description: AEM Dryflow Oil-Free Air Filter, 5" diam, 3.25" inlet, grey material
Price: $40.95
Shipping: FREE
Total: $40.95
This is where I got mine from.
Darn they seem to have taken it off their website...
edit:
Might as well take some initiative here.
Alternate sites:
www.nolimitmotorsport.com
www.sportcompactonly.com
www.performancecenter.com
store.racinglab.com
www.2nrparts.com
www.ultrarev.com
www.directtuning.com
www.sportcompactwarehouse.com
www.cardomain.com
Old 02-02-2007 | 11:19 AM
  #275
MGO630's Avatar
[QUOTE=Pyros777;805881]Darn they seem to have taken it off their website...
edit:
They did but you can call and order it over the phone I just recievied mine $42 w\cleaning kit ($10 coupon for $50+ order on web site)
ps ss sc cobalt great how to
Quick Reply: 2.0 LSJ Engine: Airbox modification
