2.0 LSJ Engine: Airbox modification
Originally Posted by Hot Carls R/T
I just got my K&N filter (E-1009) install yesterday and WOW! It runs awesome...The blower wines just like your video clips and the car destroys the tires at will now. I left the bottom of the stock airbox out too get the cold air in. I just installed the bottom slash guard back in...Nice performance mod...I am going too put the car on the dyno soon.....
I was told they were too long to fit prefectly.
If you want to use the lid you either have to cut a hole in the filter or use a dremel and take off the extension the goes into the stock filter. I cut the lid first but have just finished removing the lid and clamping on the filter by drilling a hole. Removing the lid adds much more power and a very nice sound like those above have gotten than just putting in the filter with the lid.
did you clamp that in? the KN has a lot of play in it when you try to put it on ....
as for aluminum cooling better than plasitc? Where did you get that from , metal always absorbs heat more than any thermo plastic.....and plastic doesnt get as hot as fast as metal, aluminum has the fastest heat soak ability thus a lot of heat shields use it...
Update*** Make sure if you do this mod to reset your pcm by disconnecting the neg cable for a bit. This really helps to get the PCM working with the greater airflow
Originally Posted by Mikecobalt
Juste did mine, didn't have to make a hole, I juste used a smaller cone filter and got my ratchet in to tightend the filter in place.. the sound is now awsome
#36
Thanks,, and when you say to disconnect the neg cable, for how long, and is it the one in the trunk on the battery, ruless!!!
#37
Originally Posted by SS_SC_Cobalt
yes the one in the trunk and for about 2-3 minutes
But by adding the new air filter, more O2 is getting in which has leaned out the mix a bit, which is what I am contributing the boost in power to really come from.....
#38
#39
Originally Posted by Nightcrawler
Right, the metal transfers the heat better than plastic thus cooling the air quicker.
I have both, on my sunfire the AEM intake ranges the AIT from 115 to 135deg f
on my SS s/c with the new filter and plastic intake the intake AIT is 88-95 or close to ambient
on my SRT-4 with the iceman plastic intake the AIT reads 85-94 or 1-2 deg above ambient
this on a 88-90 degree day and while driving on the highway, at ide the metal intakes jum to over 130-150 deg AIT and the plastics just over 100 hmmmmmm
#40
Just out curiousity if the K&N filter has leaned out the O2 sensor are you guys getting a solid Check engine light....I had the light come on a couple days after I put in the filter saying the car was running lean...it when't off the next day but I am running Ultra Sunoco 94 gas...anyone have this problem? Colin
#41
did you reset the pcm? reset it and let it learn, if you get a ck engine light just reset the code if you have a scan reader or autotap tuning....
Mine came on 1x and was a lean out, have not had one since, just the pcm being overly cautious...
the block learn and short and long fuel trims ARE ALL OVER THE JOINT, lol
#42
I have acquired an K & N filter from a buddy of mine, brand new never used, except there are no adaptor rings with it. Do I need to get adaptor rings to attach it or are they necessary at all?
#43
Dude........Cut the damn filter box off . I did .. I bought an e-1009 k&n filter cut the box off right below the sensor, shaved the tube down a little popped the filter on like a normal CAI and bamm a CAI! Hav had it like that for about a month and a half and it works like a champ and sounds mean. A real head turner.
#45
What is the specifications of the filter's you've used? how long and how wide is it possible to go and what would be the best size to use? I know the inlet is 3.15", but the outside dimensions of the filter. That way when I go to Autozone tonight I can get one that will fit.
#47
Originally Posted by CobaltSS422
Any update?? How is everything working out for you? Any more CEL's?
I dont have the specs on the width and tough to get since the filter is sunk in the box, but get the same filter I did or any conical filter that is not crazy big should be fine!
But now I cant hear the intake or s/c over my 3" exhaust, lol
Also if you look at this pic
the filter is a little smaller than the distance of the width so that should help getting a filter to fit
#50
I looked in my local Pep Boys store and no luck on finding the filter you bought. Maybe online? I happen to come across a K&N filter that looked similar. Do you happen to have the dimensions of the filter you got?
