2.0 LSJ Engine: Airbox modification
#780
CEL on GM Stage II?
I'm looking to do this air box mod but the sporatic nature of the CEL is a bit of a turn off. I've read quite a few pages of this thread and the CEL issue still seems unresolved. With regards to the injecor theory, has anyone lseen the CEL issue on an SS/SC with GM stage 2? I figure the larger injectors would help test this theory, and influence my decision to go through with this mod.
Thanks
Thanks
#781
I wasn't able to pull out the elbow above the airbox(the one that the mass air sensor is on) due to binding and jamming, so I returned my universal filter, and bought the K&N drop in, drilled a crap load of holes in my airbox and lid(filter wasn't installed at this time), and now I get pretty much the same effect. The holey airbox lid still holds the filter in perfect. No CELs. The only issue that I had with this mod is that in order to disconnect the airbox completely, and take off the mass air sensor, i had to remove the driver side headlight. This turned out to be more time consuming than I originally had planned. BUT, with that said, yes this thread helped, and thank you.
#782
Thanks
Thanks
#784
I have the GM stage II package on my 06 SS/SC. I put in a Spectre air filter, secured it, and removed the bottom of the airbox. We'll see how it runs. No CEL thus far, keeping my fingers crossed
#785
You shouldn't get one, but if you do there is a PCM update from GM for a CAI.
Last edited by CobaltSSilver; 03-22-2010 at 07:56 AM. Reason: Automerged Doublepost
#786
Thats interesting, I didnt know they had an update for that. I guess it holds the warranty?
I'll have to look into doing that. As of yesterday I put in a Spectre air filter, secured it, and removed the bottom of the airbox. We'll see how it runs. No CEL thus far, keeping my fingers crossed
#787
#794
alright so i have a problem. i just did the airbox mod with the aem dry flow filter. I did not remove the airbox, just took my stock one out, and installed the other one (just slid on with some force) then drilled the hole and tightened the clamp. I left the air box bottom off, and secured with a piece of plastic and some strip ties. i took it out for a test drive and couldnt hear my supercharger at all..i did just get a borla xr-1 muffler installed which is pretty loud but i thought i would be able to hear my supercharger. is there a step i missed?
#795
No, there is nothing to the air box mod. I can guarentee the issue is your loud muffler. Even people with aftermarket intakes cant hear their blowers when they install loud ass exhausts.
#796
Not true...I heard my SuperCharger with the AEM dry flow CAI and Corsa exhaust...
#798
#799
The member who bumped this thread mentioned he has a loud muffler. From the sound of it he modified his air box just fine (really no way to screw it up..... hopefully). Back in day I did the air box mod as well, but I used the K&N replacement filter. It made the blower whine louder, but nothing crazy. Add a loud muffler or catback, and it will be hard to hear the whine.
