2.0 LSJ Engine: Airbox modification
Old 06-12-2006 | 03:03 PM
  #151
mastoer's Avatar
hey guys ...ss sc cobalt u seem to be pretty knowledgeable about this mod..but this is to anybody who actully did the mod ..i really want to do this mod but from reading the responses from people who have done it i jus dont want the cel to come on...i went and bought the same filter from pep boys as ss sc cobalt did when u do the first mod if i use that filter, would i have problem if dont disconnect the batt. on the neg. terminal or even if i did disconnect would i still get the cel.....? jus a question
also why dint u have to put oil in the dryflow ? does it have a thicker membrane how is it different then regular air filters
Old 06-12-2006 | 03:45 PM
  #152
youngblood's Avatar
where can i get a dryflo and what is the fitment size or r they all the same
Old 06-12-2006 | 03:54 PM
  #153
SS_SC_Cobalt's Avatar
dry flow is an aem part# 21-2110D it uses a synthetic filter media that doesent need oiling, in fact oiling will ruin it.
you can order them from jegs, summit,etc about $45
as for the pep boys filter, do not over oil it, keep it way light and let it sit for a day or 2 before you use it after you oil it. the problems with this stuff stems from the oil getting on the MAF wire.
Old 06-14-2006 | 04:47 PM
  #154
mastoer's Avatar
thanks for the great how to the csr gets up qucik as hell nd the s/c screams and gets attention
Old 06-14-2006 | 05:18 PM
  #155
no problem!
Old 06-14-2006 | 08:39 PM
  #156
mastoer's Avatar
I GOT A CEL WITH THE PEPBOYS FILTER...BUT WHEN I PUT ITON THE OBDll SCANNER IT JUS SAID ERR ..IT DID NT GIVE ME A CODE IMMA TRY THE DRY FLOW
Old 06-14-2006 | 08:51 PM
  #157
you probably got P0171, sounds like your ob2 scanner isnt compatible with the SS
Old 06-14-2006 | 08:56 PM
  #158
blowncobalt's Avatar
I did that too....sounds great doesn't it.
Old 06-14-2006 | 09:40 PM
  #159
mastoer's Avatar
Ss Sc Cobalt ..After I Get The Dry Flow And Put Thet On Would I Have To Reset The Whole System Again OR WOULD I HVAE TO GO GET THE PCM REFLASHED BY THE DEALER MY SS S/C COBALT IS BONE STOCK EXCEPT FOR THE AIR BOX MOD....and That Is The Code I Got Any Input On Y?
Old 06-14-2006 | 09:48 PM
  #160
just have to clear the code
Old 06-14-2006 | 09:59 PM
  #161
mastoer's Avatar
Ok Kool I Jus Keep Reseting It Now...would That Have An Effect On It Until I Get The Dryflow?
Old 06-14-2006 | 10:00 PM
  #162
peg's fastest ss's Avatar
with the aem part number 21-2110D does the bottom of the air filter box go back on or do u have to modify it to fit... i know to tighten it u need to put a hole but will the bottom go back on??
Old 06-14-2006 | 10:12 PM
  #163
bottom will go back on if you want, and dont worry so much about the code GM itself said it doesnt affect performance, just annoying
Old 06-14-2006 | 10:15 PM
  #164
i live in winnipeg and if u ever been up here its scary to leave ur air box that exposed lol....if its not water its 10 feet of snow or a blanket of mosquitoes or dust from all the construction i think it would just be the safer bet!
Old 06-14-2006 | 11:36 PM
  #165
CobaltSSilver's Avatar
Ya know with that being said I wonder if GM will put out an Update to keep this from being an issue. I mean they at the moment don't have a need or real benefit to do that but I wonder if folks barked often and loud enough something would get done. That is the only thing keeping me from going with an aftermarket intake.
Old 06-15-2006 | 07:58 AM
  #166
I have the bulletin here from GM and they are working on it
But Hell is due to freeze over then this update should be ready
Old 06-15-2006 | 06:05 PM
  #167
Great info man! Thanks! Let us know if/when they actually get it done.
Old 07-02-2006 | 02:22 AM
  #168
rocco11189's Avatar
My check engine light went on after installing mine did this happen to any of you?
Old 07-02-2006 | 03:14 AM
  #169
c0al67's Avatar
damn, that sounds crazy lol.
Old 07-02-2006 | 10:20 AM
  #170
did you over oil the filter?
Old 07-03-2006 | 01:13 AM
  #171
rocco11189's Avatar
I really dont think so but the same thing happened to my friend with his car. Is this happening to anyone else? Also am i throwing the oxygen sensors off and thats why the check engine light goes on?
Old 07-03-2006 | 09:48 AM
  #172
get the code then we will know what it is.... BTW there is a reflash that supposedly fixes this dated 6/21
Old 07-03-2006 | 04:35 PM
  #173
rocco11189's Avatar
How do i get the code and where do i get the reflash. Also when installing my filter i didnt put the cover back on the bottom of it that was under the stock filter is that a problem?
Old 07-03-2006 | 05:51 PM
  #174
rocco11189's Avatar
Now my rpm's arent going up instantaneously when i hit the gas pedal it waits then goes up is this due to the filter can anyone help me?
Old 07-03-2006 | 10:03 PM
  #175
go to autozone or something and they can use a code scanner to get the code.
Quick Reply: 2.0 LSJ Engine: Airbox modification
