All Engines: another way to reset your oil life %
ok so hold the button down while its off, and then put the the run position? or do i put it into accersorie mode and then hold down and then put it into run?
1 Post
Here's a copy of the online owners manual insert for resetting the OLM.
http://fr33k.5gbfree.com/oillifereset.htm
I figured out another way to reset the oil life % here are the steps:
1.put the ignition "on" position but don't start the car.
2.press the accelerator pedal more than 2 times in a row.
3.your oil life will be @ 100%
Note:When you do this procedure the info display does not need to be in the oil life % can be any where!
Let me if this works on others cars hope this was useful!
thers another way to reset these?. this type of method works on all newer GM cars. this is how we were tought to reset them at valvoline instant oil change when i worked there.
#37
Pushing the pedal to the floor 3 times was the only way to do it in older GM models with the oil life monitoring system, ie 99-2002 Silverado's. There were no menu buttons to push and hold. Thats cool it works as well though.
importkiller
09-30-2015 07:18 PM
