Interior: Disassemble Dashboard - Radio and related panels
Old 11-23-2009 | 12:34 AM
  #76
ThiZo_19's Avatar
awesome write up good job
Old 11-23-2009 | 08:00 PM
  #77
tru2nrtt777's Avatar
Originally Posted by Ubergeff
To further remove the cup holders section of the e-brake and section containing the shifter. All these pieces just pop off, just pull them. The shift boot is attached to a ring that you can snap off after you get the main piece off.
The easiest way I have found about removing that is to pull the ebrake up and put it in neutral, removing the section around the ebrake first, then the forward and aft panels, you can also remove the front cup holder by sticking your fingernails under the front of it and gently pulling back and up, then once the front is released go up and slightly forward to release the two rear tabs.
Originally Posted by LewiSS
Great pics! It looks like the dash top is held on with screws behind the panels you removed. Has anyone taken the next step to remove the dash top? I need to track down a rattle above the glove box and behind the air bag chamber.
Thanks again!
Yes, simple removal and installation with the right tools. First remove the a pillars(remove bolt at top then pull out and up), then remove the front part of the dash(where the light sensor is), unclip the light sensor(harness is short so be careful), remove trim(DIC panel, passenger panel, radio panel, and the one controlling interior lights) undo all bolts(7 and 10 mm if I remember correctly) pull up and towards seats, slide out passenger side.
Old 03-01-2010 | 10:28 PM
  #78
Brenticus's Avatar
sub'd
Old 11-15-2010 | 09:37 AM
  #79
ReaperSS's Avatar
Nice post man...wow do I feel for bacon!
Old 12-31-2010 | 02:19 PM
  #80
redrocketss/sc's Avatar
Is that ur stock radio what year
Old 10-14-2011 | 12:49 PM
  #81
CobaltItaliano's Avatar
subd
Old 10-17-2011 | 07:30 AM
  #82
Brian MP5T's Avatar
Old 10-18-2011 | 07:41 AM
  #83
Getaway_Driver's Avatar
Originally Posted by Brian MP5T
x2
This how-to will come in handy for what I plan on doing, which is either vinyl wrapping the ugly silver trim or just using Plastidip to make it look better.
satisfied
10-19-2015 01:35 AM
agentirons
10-16-2015 03:11 AM
09-26-2015 07:44 PM
dieGone
09-23-2015 11:20 AM
chris88z24
09-08-2015 02:55 PM
