Appearance: How To: 3rd Brake Light LED Conversion!
Old 12-19-2014 | 12:59 AM
  #101
EmperorJJ1's Avatar
pics?
Old 12-22-2014 | 10:57 AM
  #102
DFZ24's Avatar
Originally Posted by supernovanator
So are you guys splicing yours into your wiring or making it so you can plug and play directly into your existing setup?
This is mine
Is been like that since day one, like over 5 years ago lol
Originally Posted by mikessssc
I have wanted to do this conversion for so long i am excited to be done finally! I got mine at a junk yard for $11. I spent more time than most of you guys i would imagine, but hopefully my extra efforts will pay off so i don't have to get back in there. I kept that grey piece that the board is attached to, so that the board would have ''back-support.'' This took a lot of sawing and cutting out everything EXCEPT the FLAT part the board snaps onto. That made it easier to glue it into the housing. I also flattened out the two points that come up in between the original 3 bulbs(to give the 2 surfaces more contact area in hopes that i won't have to pull it all out and start over the first time i close my trunk.) in response to someone asking about splicing: i just kept the ends and plugged into the pigtail, just make sure to put insulation around the ends, its obvious but i was dumb and blew my fuse when i accidentally touched the two wires together plugging them in.
Why go through all this trouble? Double side tape it and it works, heavy duty double side tape.
Fearedbynone
04-14-2016 04:25 AM
01-12-2016 01:01 AM
biniecki
10-25-2015 03:23 PM
09-27-2015 09:53 PM
