General Suspension: How-to: Adjusting the emergency - parking brake on 05-09 Cobalt w/ rear disc brakes
Old 01-08-2012 | 12:54 PM
thejobman's Avatar
Originally Posted by evilfrog
any chance you can fix the photobucket pictures?
+1
Old 01-25-2012 | 02:36 PM
cobaltsssc760's Avatar
it needs new pics i think i have a huge drag problem ever since i installed my baer big brake kit
Old 02-05-2012 | 10:48 PM
dakotaspeir's Avatar
#cobalthoes
new pictures would be great. went to the dealer and they wanted 160 bucks to clean the brakes and adjust it lol.
Old 04-14-2012 | 06:10 PM
BlackLsCoupe's Avatar
pics are gone. hate reading. i think mine need adjusted
Old 04-15-2012 | 02:52 PM
AARON-SS-TC's Avatar
mine is done and perfect again. i had to compress the piston then twist is to get it going. it was completely locked up on both sides...btw, the universal piston tool does not work!!! i ended up using needle nose pliers
Old 04-24-2012 | 12:52 AM
09BlackSSIL385's Avatar
Originally Posted by Baron7700
After having GM adjust mine three times, i went to the dealer today for them to do it again because it came loose and wouldnt hold. They made the handle tight again, and we tested it on a small ramp. Oddly, it did NOT hold, they went back in, and said my rear calipers were messed up, something with the guide rods not going in all the way / clamping so they ordered new ones. Im cool with that.
I've had to adjust mine twice since I got the car in October. I have a fairly steep incline in my driveway, and i adjusted it to where 5 clicks holds it towards the bottom, 6 clicks will hold it at the top. But for some reason, after about two months the cable will loosen up slowly. Any thoughts on what's causing this?
Old 04-24-2012 | 01:16 AM
lilskarvcx's Avatar
same problem here
Old 09-02-2012 | 05:15 PM
rchiwawa's Avatar
I figure it's the nylon threads common to the adjustment nut. I dabbed some locktite infront of it to see if that will stop it from moving. I figure worst case scenario I'll have to destroy the nut to remove it, and spin an all steel nut down to remove the locktite but my guess is that I am not going to be adjusting this thing anymore.
Car was purchased April 2010 new. I use the ebrake daily (every once in a while for "hektik skidz") and just now it topped out the mechanical movement of the handle while barely being able to hold the car on a moderate hill(4% incline, driveway). It has 70k miles and I have replaced the rear pads and rotors once (rotors for that aftermarket black powder coat and personal policy of rotors and pads being installed as pairs... overkill for the rears, I know.)
Old 03-06-2013 | 11:53 AM
vahdyx's Avatar
I would like to try this today. Any photos available?
***Edit***
I figured it out with just he descriptions.
Old 03-22-2013 | 01:47 AM
Pitbull2o08's Avatar
Wish photos were available in the How To section...
Old 04-27-2013 | 12:26 PM
  #36
neumannl001's Avatar
Exclamation Emergency Brake Replacement
Spent a ton of time searching this site and did not get the answer I needed. Does anyone know where to get a new Ebrake assembly? The button and what ever springs or plastic crap that holds it together is broken. The chevy dealership in my area wants to sell me a new one for $110 + Labor. Sounds like the typical screw the driver scheme to me. Anyway, is there a sturdier after market replacement?
Old 09-15-2016 | 01:27 AM
  #37
Tehmaster's Avatar
Wish the pictures worked :/
Old 02-05-2019 | 03:58 PM
  #38
Evilfrog's Avatar
Ditto.
CobiJack
11-07-2016 10:25 AM
Crazypolak00
03-30-2013 01:36 PM
Stevo
07-05-2011 02:09 PM
RAIDERNATION 433
08-21-2010 01:19 PM
averagewhiteboy
01-25-2010 07:10 PM
