Appearance: how to change fog lamp bulbs.
1. If you can put the car on a lift it makes it much easier.
2. The lamps are accessable by prying open the plastic panels on each side. Try to push or position your wheels front facing outward on the current side you are working on. There are approx 3-4 screws on each side, the passenger side having 1 or 2 more, and 2 "pull tab fasteners" (tm) on each side that need to be removed for access. It may look like you need to remove the entire wheel well for access but it is not necessary. Just keep unscrewing and unfastening until you can pull the panels apart to access the foglamps. try not to bend them to much or you might break them but don't be too concerned they are pretty durable.
3. Just like any other bulb, turn to release from the housing. Use a flat screwdriver or other flat thing to release the tab holding the h11 in. MAKE SURE NOT TO TOUCH THE GLASS ON THE BULBS OR THE OIL FROM YOUR FINGERS WILL BURN THROUGH THE GLASS!!! Reinsert the bulb and turn the opposite way to fasten it back in.
4. Repeat step 2 in reverse.
5. Enjoy fog lamps!
5. Enjoy fog lamps!
Couldn't you just reach through the opening left by removing the headlight? I can see this being a possibility because, well, I spent a good 3 hours trying to take off, install, and re-install the wheel well and screws for my intake, not looking to do it again.
The oil itself won't burn the glass up.
Yes you can i just did very easy just take note the position of the light socket when the bulb is tight and when you un screw it. makes it easier to screw back in.
wow dood. either way the ******* bulb gets burnt out by the oil from the finger. To the OP good write up dood. and perfect disclaimer. no need to change anything
well from personal experience next time (for the driver side) i think i'm going thru the wheel well... air horn gets in the way. (thank god for little hands)
however the headlight has plenty of room for those people with big hands. lol
importkiller
09-30-2015 08:18 PM
roth
09-26-2015 01:16 PM
