Drivetrain: How To: Clutch Job on Cobalt SS
Old 02-20-2012 | 01:55 PM
Frogstofall's Avatar
I hope this helps someone. I know I would have liked to have this when researching what I needed to do mine. I did the write up in PDF form so I will link it here.
Thanks goes to James (Chevycobaltss3) and Nick (ccrunner84).
https://app.box.com/shared/35cb5d8e1179737b6a45
http://frogstofall.f3h.com/Clutch%20...obalt%20SS.pdf
Old 02-20-2012 | 07:02 PM
Chevycobaltss3's Avatar
A+ .. thanks bro to you for also being there helping...
Old 02-20-2012 | 07:17 PM
BlkSS4dr's Avatar
VERY VERY VERY good write...Prob. the best one I have ever seen. Thank you
Old 02-20-2012 | 07:19 PM
09xfebalt's Avatar
Proper way to bleed clutch on these is to apply vacuum to reservior and works alot faster and easier.
Hydraulic Clutch System Bleeding
Special Tools
J-35555 Metal Mityvac
J 43485 Power Steering Bleeder Adapter
1.
Verify that all the lines and fittings are dry and secure.
2.
Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
3.
Remove the reservoir cap.
4.
Fill the reservoir to the proper level with the required fluid.
Some manual transmission equipped vehicles have a combined brake and clutch fluid reservoir.
5.
Attach the J 43485 power steering bleeder adapter to the J-35555 Metal Mityvac, or equivalent.
Note: Brake fluid will deteriorate the rubber on the J 43485 power steering bleeder adapter. Use a clean shop cloth to wipe away the fluid after each use.
6.
Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
7.
Apply a vacuum of 51–68 kPa (15–20 hg) and remove the adapter.
8.
Refill the reservoir to the proper level.
9.
Repeat steps 6 and 7.
10.
If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
Warning: The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational. Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see if the transmission will shift easily into gear.
11.
Pump the clutch pedal until firm (to refill actuator cylinder).
12.
Add additional fluid if needed.
13.
Test drive the vehicle to ensure proper operation.
Old 02-20-2012 | 09:44 PM
CCrunner84's Avatar
Looks good! We tried the 'proper' way but it didn't seem to work at all, pedal was always on the floor. We could have been doing something wrong but it seemed pretty damn straight forward.
Old 02-20-2012 | 10:09 PM
Thanks! We tried!
Ditto. It didn't seem to do anything when doing the vac first.
Old 02-20-2012 | 10:14 PM
09xfebalt's Avatar
Originally Posted by Frogstofall
Thanks! We tried!
Hmmm....Well I would always fill the slave on the bench with fluid before installing so that may have made the difference too.
Old 02-20-2012 | 10:21 PM
I could see that making the difference.
Old 02-20-2012 | 10:34 PM
kikal8's Avatar
ha ive seen this post before.. this guy JACKED IT
Old 02-20-2012 | 10:44 PM
Traviper's Avatar
awesome professional write up!
Old 02-20-2012 | 11:53 PM
Huh? Who jacked what now?
Old 02-21-2012 | 08:45 PM
07cobalt_LT's Avatar
great right up
Old 02-21-2012 | 09:25 PM
T CUPP's Avatar
subd
Old 02-26-2012 | 02:23 AM
Boosted4's Avatar
Excellent how-to, very detailed. Nice job guys
Old 02-27-2012 | 11:30 AM
Thx again guys.
Old 02-27-2012 | 11:37 AM
ei3dag3's Avatar
Thanks man!
Old 02-27-2012 | 02:19 PM
StevoElSupremo's Avatar
awesome man, I love a proffesional looking PDF... but good God I'm not going near this project with a 10ft pole! :O
Old 02-27-2012 | 02:37 PM
So easy!!!!!!!! Lol.
Old 02-27-2012 | 08:23 PM
It looks worse than it is. With the proper tools, its not that bad. That being said, I'll never do it agin....
Jk
Old 02-27-2012 | 09:13 PM
^ when you spin I can't get a correct 60-100 .. so stop spinning.
Old 02-27-2012 | 09:29 PM
05Slowline's Avatar
what a bunch of homos. yall can come do mine .
Old 02-27-2012 | 09:33 PM
SSlobalt's Avatar
AWESOME!! You guys are my new heroes. I was talking to interviewatruins about doing this job ourselves on our cars. I have everything except the vac bleeder, which I still don't understand. Do you guys have any pics of that part?
Old 02-27-2012 | 09:43 PM
ItalianJoe1's Avatar
Are you guys doing the vac bleeder process correctly? I bleed all my clutches like that and they come out perfect with no drama. It takes 3-4 cycles as per the instructions, first couple times it feels like nothing changed, then all of a sudden you will have a nice normal pedal with no mess. I set it up while i'm putting back the final parts and let it bleed while i'm working, then go drive the car. Easy as pie.
Old 02-27-2012 | 09:45 PM
I just made the how to ... Most of it lol they did the work since I'm here in lonely ky and they are up north
Old 02-27-2012 | 10:00 PM
bamaboy22's Avatar
who was wearing gloves?
Quick Reply: Drivetrain: How To: Clutch Job on Cobalt SS
