Drivetrain: How To: Clutch Job on Cobalt SS
Old 02-28-2012 | 02:50 PM
CCrunner84's Avatar
Originally Posted by ItalianJoe1
Are you guys doing the vac bleeder process correctly? I bleed all my clutches like that and they come out perfect with no drama. It takes 3-4 cycles as per the instructions, first couple times it feels like nothing changed, then all of a sudden you will have a nice normal pedal with no mess. I set it up while i'm putting back the final parts and let it bleed while i'm working, then go drive the car. Easy as pie.
It may have worked, it was getting late, I think we just wanted to get it done. This method seemed to work just fine too, haven't heard him say anything negative about the pedal.
Originally Posted by bamaboy22
who was wearing gloves?
Pretty sure my hands are in most the pictures, so I'm guessing me lol.
Old 02-28-2012 | 03:15 PM
1AJeremyD's Avatar
Subd
Old 02-28-2012 | 05:38 PM
bamaboy22's Avatar
Don't make me say it!
Old 02-28-2012 | 06:03 PM
Frogstofall's Avatar
Don't make you say what?
For the person who asked, this is the vacuum kit I purchased...
Mityvac Vacuum Pump - Save on Mityvac Pumps at Harbor Freight!
Old 03-01-2012 | 01:10 AM
Wangspeed's Avatar
Ugg. I'm too busy to do this myself. I guess I'm gonna have to find someone in the NoVA area, unless I can magically deglaze my clutch.
Old 03-07-2012 | 06:36 PM
SSlobalt's Avatar
Found this for those looking to save some moola.
clutch bleeding from the mc (or the j-43485 mityvac adapter) - Corvette Forum
This is what I plan on using, though. Why not, for $75?
Old 03-09-2012 | 06:28 AM
The one I linked to from Harbor Freight comes with the little plunger thingy you put in the resovuir to create the seal.
I did see on someone's YouTube video that there exists a kit that uses your spare tire as a pressure source and just pushes the fluid out until there are no more bubbles. Looked pretty neat. I think it was called EZ Bleed or something.
Old 03-09-2012 | 07:29 AM
mongorat427's Avatar
I used the bottle on the ground method. Hook a rubber hose to the bleeder and place it in a half full bottle of brake fluid sitting on the ground under the car. Pump the clutch pedal a couple times and open and close the bleeder nut. Check the fluid level. Repeat as needed. Took me about 4 cycles to bleed my stage 3
Old 03-09-2012 | 08:05 AM
Powell Race Parts's Avatar
^^^ I agree with Mongorat.
Old 03-09-2012 | 08:08 AM
Dart_SI's Avatar
Lots of downshifting. The clutch will slip a different way on the flywheel so it unglaze it faster.
Old 03-09-2012 | 11:34 AM
  #36
Chevycobaltss3's Avatar
Gravity and force bleeding is fine if you4sing the old slave Tob.... If you don't have fluid in the line that goes.down to the Tob, it'll be a Bitch getting those air bubbles out just by gravity or force bleeding. Which is why vacuum is best. (Per gm)
Old 03-18-2012 | 09:45 PM
  #37
AARON-SS-TC's Avatar
awesome write up...sooo flippin involved though..it looks like its worth the 900 the dealer wants to do it...
Old 03-18-2012 | 11:33 PM
  #38
ItalianJoe1's Avatar
Not worth that much, but I won't do them for less than $350, because it is a pain in the ass.
Old 03-19-2012 | 12:29 AM
  #39
Def not worth letting the dealer do it. Once you do it you'll realize you could do it again in half the time. It's really not that bad, just a lot to do and time consuming. It's not mentally challenging more physical.
Old 04-10-2012 | 06:24 AM
  #40
Bump BC the other guides don't have any pictures!!!
Old 04-10-2012 | 09:06 AM
  #41
bou20011's Avatar
This is diff gonna come in handy! Cheers man
Old 04-10-2012 | 09:20 PM
  #42
I knew you were from Canada just by reading ure post... Lol.
Old 04-22-2012 | 02:39 PM
  #43
Dan-o's Avatar
where did you buy your flywheel from?
Old 04-22-2012 | 06:01 PM
  #44
CCrunner84's Avatar
I believe he got it from CED.
Old 04-23-2012 | 11:19 PM
  #45
I actually got it from Mongorat. PM him as he usually has something.
Old 04-23-2012 | 11:34 PM
  #46
mongorat be good for this for sure
Old 04-23-2012 | 11:35 PM
  #47
turbos are a walk in the park compared to lsj....stop ur whining.
Old 04-28-2012 | 09:30 PM
  #48
Dan-o's Avatar
ok thx has anyone ordered a LNF flywheel from zzp i see they are selling them for 150 and CED is like 750 big price difference starting to wonder if its a typo
Old 04-29-2012 | 01:53 AM
  #49
chris88z24's Avatar
There's no way to remove the tranny with the engine brace still in place?
Old 04-29-2012 | 01:57 AM
  #50
Naw, they are pretty pricey from GM. Ever looked up how much an LNF wheel costs brand new? It's insane.
James says he can do it with only lowering one side. Maybe he'll chime in.
Quick Reply: Drivetrain: How To: Clutch Job on Cobalt SS
