Drivetrain: How To: Clutch Job on Cobalt SS
Old 04-29-2012 | 02:00 AM
  #51
BriantheLion26's Avatar
Thanks to all who put this How-To together. I printed it off and used it when I did mine last weekend installing the gmpp clutch. Worked perfectly with only minor differences when doing an LSJ. Total time took around 6hrs on a post lift and air tools.
Old 04-29-2012 | 07:01 PM
  #52
ItalianJoe1's Avatar
There's no way to remove the tranny with the engine brace still in place?
No, the trans will not come out of the car without dropping the subframe.
Old 04-30-2012 | 01:33 AM
  #53
chris88z24's Avatar
Only reason I ask is because I've dropped an older Civic transmission and there was room to literally just unbolt the trans from the engine and have it fall out.
Old 04-30-2012 | 01:40 AM
  #54
Frogstofall's Avatar
James (Chevycobaltss3) says he can do it by just dropping the transmission side of the cradle only. Shot him a PM and ask bc I can't remember exactly how he does it.
Old 04-30-2012 | 10:34 AM
  #55
Chevycobaltss3's Avatar
You dont have to remove the subframe. But you need.to remove the drivers side cradle bolts and loosen the passenger to 3/4 out.
Old 04-30-2012 | 02:48 PM
  #56
CCrunner84's Avatar
If your doing this for the first time I'd drop the cradle. If you didn't it would probably make things really difficult, especially when trying to get the trans in, and then lift and align it with all that crap right there.
Watch it when removing the cradle too, I thought I had one bolt in holding it while removing the other and it came crashing down on my hand lol.
Old 05-19-2012 | 11:18 PM
  #57
KriSS09's Avatar
Just me, or is the link not working anymore?
Old 05-20-2012 | 12:06 AM
  #58
Hmmmmmmm..... It is down. Let me see what's up. If it's not back up in a couple hours, I'll try to move it to another host.
Old 06-05-2012 | 10:47 PM
  #59
fastfreddy7's Avatar
Any word? My clutch just went, and local places are quoting me anywhere from 850-1580$ to do it, Id rather do it myself if possible.
Old 06-05-2012 | 10:57 PM
  #60
Ah ****. Lemme try to find a new host. Can you email me? I can send it that way in the meantime.
Frogstofall at yahoo dot com
Old 06-06-2012 | 02:24 AM
  #61
SCoBaLtC's Avatar
link not working..
Old 06-06-2012 | 02:39 AM
  #62
Originally Posted by SCoBaLtC
link not working..
Old 06-15-2012 | 10:34 AM
  #63
2007cobaltsc's Avatar
link doesnt work still
Old 06-15-2012 | 05:40 PM
  #64
Yes that is correct. I guess the server is officially dead and I have not tried to get another host yet.
You can EMAIL me for the guide.
Old 06-18-2012 | 02:32 PM
  #65
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
What's your e-mail address?
Old 06-18-2012 | 03:36 PM
  #66
Old 06-27-2012 | 01:50 AM
  #67
Fastgti69's Avatar
I'm emailing you cause I need the file too!
Old 07-03-2012 | 10:05 AM
  #68
Aleksey's Avatar
Emailed
Old 07-03-2012 | 03:14 PM
  #69
Aleksey's Avatar
Just got the PDF in the mail. Thanks a lot man, great write up and pictures definitely help.
Old 07-05-2012 | 11:25 PM
  #70
1SLOLT1's Avatar
Emailed
Old 07-05-2012 | 11:59 PM
  #71
padlock's Avatar
you try uploading on scribd or another site? I'm going to want this PDF as well, and I will email you about it too
Old 07-06-2012 | 08:16 AM
  #72
Powell Race Parts's Avatar
Italian Joe is right, but then there are always people who will try and butcher something by taking short cuts that dont work out. an hour trying to re-mate the trans into the clutch assembly because the cradle is in the way or the clutch is not aligned is simply counter productive.
remembering that the rad assembly needs to be supported, and taking out assemblies in order to facilitate next steps helps; ic pump swung to one side to make it easier to get to the trans bolt above the starter motor; rack left behind to avoid fooling with the steering shaft and potential clock spring damage in the steering wheel; remove the entire rear motor mount assembly and the entire axle im shaft; plugging the distribution block to avoid dripping brake fluid everywhere; filling trans with fluid before replacement if trans is serviced; using plugs for the trans output shafts;using a nut driver to loosen tob bolts;using a proper clutch alignment tool;using an angle torque wrench for flywheel bolts or measuring 25 degrees with a marker (one hex flat of travel);using 145 ft lbs for the cradle bolts;using penetrating oil on cradle bolts up top before removal and rust check for reassembly;bleeding the clutch on reassembly before replacing the cradle to make access easier.
etc,
Old 07-08-2012 | 03:47 PM
  #73
mmack104's Avatar
Emailed!
Old 09-13-2012 | 10:52 AM
  #74
trixx209's Avatar
Could I get a PM of this ? says the link is down
Old 09-13-2012 | 10:57 AM
  #75
Italian joe is incorrect as are you. You don't have to remove the cradle, remove driver side subframe bolts completely and passenger side 1/4-3/4 the way out and have a jack holding it as well if on te ground. It can be done... Without breaking one thing
etc,
