2.0 LSJ Engine: HOW TO: DIY Dual Pass Endplate (pics inside)
Old 11-10-2009 | 09:59 AM
schamsy's Avatar
Here are a bunch or pics and short explanations. ENJOY!
Sorry in advance for the crappy cell pics.
This picture shows the 5 bolts and the 2 nuts that need to be removed on the intake manifold to get that off, also see the next picture showing the bolt on the underside.
Here is the screw that is on the underside of the intake manifold.
Here is the screw that is holding the oil tube in place.
Showing the laminova cores swapped out.
Here is the 1/2" NPT aluminum bung welded to the endplate.
Showing the connection from the intercooler pump the the in on the endplate. The in is the newly added connection.
This is the TEE I made I had this 90 sitting around and it will do the job.
This is the stock filler cap showing where it connects to.
Thats enough pics of the dual pass endplate... thought I might as well throw a 2.8 on there now that my cooling mods are adding up.
Shot of the car while I was waiting for the welds to cool down.
I hope this helps explain the custom dual pass endplate.
Old 11-10-2009 | 12:56 PM
SCcobaltSS's Avatar
isnt there a HOW TO GUIDE section?
Old 11-10-2009 | 03:06 PM
schamsy's Avatar
Yes but I basically just wanted to show people how easy this is.
Old 11-10-2009 | 10:36 PM
rollingboostedss's Avatar
I thought it was better put together then the other ones I have seen good job
Old 11-10-2009 | 11:45 PM
schamsy's Avatar
Thanks, if you can weld aluminum you can save big bucks and do this mod.
Old 11-11-2009 | 12:36 AM
mrbelvedere's Avatar
on thing you might want to consider is taking the endplate to a machine shop and mill the the endplate to make sure it is flat so it dosent leak lol like mine did awsome pics nice and clean ride
Old 11-11-2009 | 12:39 AM
elite_Cyborg's Avatar
I like that pulley
Old 11-13-2009 | 10:59 PM
Fast Freddy's Avatar
u making those to sell? I want one! GREAT JOB!!
Old 11-14-2009 | 12:32 PM
schamsy's Avatar
no not selling them... just trying to help everyone out. If you buy the right stuff just take the endplate to a welder and have him weld the bung on the endplate it... It would probably cost you $50 for everything including...
Old 11-14-2009 | 01:52 PM
advise's Avatar
where did you get the bung?
Old 11-14-2009 | 02:00 PM
schamsy's Avatar
Right here...
Old 11-22-2009 | 03:22 PM
Black SS/SC 06's Avatar
Approved
Old 12-01-2009 | 01:21 AM
advise's Avatar
did you replace the seal also
thanks
Old 12-01-2009 | 01:27 AM
ItalianJoe1's Avatar
Or you can drill/tap the endplate if you don't have access to a welder, just a suggestion.
Old 12-01-2009 | 02:52 PM
advise's Avatar
i thought blown 4 banger tried that and there wasnt enough material to hold he fitting in?
Old 12-01-2009 | 02:53 PM
advise's Avatar
did you replace the endplate gasket??
Old 12-01-2009 | 02:59 PM
schamsy's Avatar
That is asking for failure. there is probably 3mm of nice soft cast aluminum in that spot.
Old 12-01-2009 | 03:02 PM
schamsy's Avatar
No... and I have no leaks, but thats not to say someone else might.
Old 12-01-2009 | 03:43 PM
SSfamilywagon's Avatar
No you can drill and tap just fine. It's how I did mine and has held up for months now.
Old 12-01-2009 | 05:29 PM
advise's Avatar
really i think im gunna tap it and put a couple tacks on it
where did you get the tap and what size
Old 12-01-2009 | 05:37 PM
Micro's Avatar
Originally Posted by schamsy
Thanks for that link! I have been looking for a website like that for a while!
Eric
Old 12-01-2009 | 05:44 PM
advise's Avatar
ya ill see what condition its it, also what size bit did u use to drill the hole
Old 12-01-2009 | 05:48 PM
SS33's Avatar
FYI, early model cobalts should replace the intake manifold gasket for the updated part # (available through CED) while your at it. I think 07s came with the redesigned gasket (not 100% sure), but 05 and 06's did not AFAIK. I'll dig up a pic of the redesigned gasket from my gallery so you can compare the new one to the original (shown in the OP).
Nice write up though, this was one of my least favorite jobs to do on the LSJ. Getting the IM/intercooler off is a pain in the ****.
Re-designed gasket
Old 12-01-2009 | 08:04 PM
Thread merged with your other thread. Please don't make duplicate threads.
Old 12-03-2009 | 01:21 AM
1/2 in npt pipe tap
