2.0 LSJ Engine: HOW TO: DIY Dual Pass Endplate (pics inside)
Old 12-07-2009 | 07:25 PM
advise's Avatar
whats used to make the hole for the bung
Old 12-07-2009 | 07:37 PM
SSfamilywagon's Avatar
Mine has no bung on it at all. I just used a 1/2'' drill bit, tapped it, then used a good sealer.
Old 12-07-2009 | 09:30 PM
ItalianJoe1's Avatar
Originally Posted by schamsy
That is asking for failure. there is probably 3mm of nice soft cast aluminum in that spot.
I've done probably 30 of them like that and none leaked...
If you know what you are doing, it works. I wouldn't advise the average person to go out and stick a 23/32nds drill through thier enplate and tap it, it is easy to crack the cast aluminum and it is thin. If you do it right though, it's much simpler than welding.
Old 12-07-2009 | 10:23 PM
advise's Avatar
nah im gunna stay away from tapping im just wondering what schamsy used to drill the hole the backside of the bung is 1" where do you get a bit that big, hole saw?
Old 12-08-2009 | 02:09 AM
1" is gonna be the full width of the endplate in the middle...
Your hose is only 3/4" inside, I wouldn't see a reason to go bigger than that on the drilling, unless you are tapping it.
A hole saw might work, but it just seems like a bad idea to me. I use a regular drill bit with a 1/2" shank, in whatever size I need. I think the actual size for 1/2 NPT is 37/64th's, or possibly 35/64th's, not sure. Thats for threading though. It doesn't leave you a whole lot of room, you have to position it correctly to make it work without drilling into the side walls.
Old 12-10-2009 | 09:23 AM
BCobaltSS's Avatar
I might add to make sure that you blue loctite the bolts. I went to re-do mine after 2 years because I did not swap the tubes while I was doing my clutch, one of the end plate bolts had fallen out. Good thing it was still wedged between the manifold and the endplate. No leaks luckily but I had inched the gasket
Also make sure that you remobe the alternator bracket as the manifold will not come off unless you remove this bracket.
Old 12-13-2009 | 07:05 PM
RooTBeeR's Avatar
subed for later
Old 01-13-2010 | 10:41 PM
chevysssc's Avatar
do u have to swap the cores
Old 01-13-2010 | 10:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
yes, that's the most important part
Old 01-13-2010 | 11:10 PM
chevysssc's Avatar
i dont know **** about the dual pass im having a shop do it when they install my head just want to get my **** straight so i can explain to them wish me luck
Old 01-14-2010 | 12:49 AM
  #36
Where are you getting your endplate from?
Old 01-14-2010 | 01:52 PM
  #37
chevysssc's Avatar
OTTP...Unless you have one for sale?
Old 01-30-2010 | 12:04 PM
  #38
chevysssc's Avatar
subd
Old 01-30-2010 | 12:10 PM
  #39
Brenticus's Avatar
Sub'd
Old 02-05-2010 | 09:46 PM
  #40
utibalt's Avatar
did you need to replace the seal for the endplate? i'm getting a dual pass soon..
Old 02-05-2010 | 09:54 PM
  #41
eurochevy's Avatar
pretty sure theres a diff thread for how to install
Old 02-06-2010 | 01:21 AM
  #42
YzRider452's Avatar
No u dont need to replace the gasket, unless u rip it.
Old 02-06-2010 | 03:50 AM
  #43
utibalt's Avatar
alright kool, cuz zach said i should, but i don't see the need in one either..
Old 02-06-2010 | 06:31 AM
  #44
YzRider452's Avatar
They are 100% reusable.
Old 02-17-2010 | 09:36 PM
  #45
utibalt's Avatar
since you gotta take off the intake mani shall i consider changing that gasket?
Old 02-18-2010 | 01:55 AM
  #46
YzRider452's Avatar
Yes, you have an 05, you should change it anyways. Get the update one so ur dipstick doesnt pop out.
Old 03-26-2010 | 01:50 PM
  #47
G11's Avatar
G11
so since i have an 07 i should be fine with the intake manifold gasket as far as the updated one? and is that one reuseable as well?
Old 03-26-2010 | 02:00 PM
  #48
Yes, the intake manifold gasket is metal and re-usable. If you've had it off many times, i'd say replace it anyway, but i've never had a sealing problem re-using one even after many times on and off.
If you need a dual-pass endplate, contact me.
Old 03-26-2010 | 02:13 PM
  #49
G11's Avatar
G11
i may be purchasing the one from sunburst lol....isn't that one you made? i want to do this but i'm afraid if i **** something up im screwed and my warranty will be gone.... i want to do this tho so my temps are cooler and im also going to be doing a h/e soon and figured just do both at the same time
Old 03-26-2010 | 03:22 PM
  #50
Yep, sure is
It's not that hard to do, if you take your time and follow the instruction (there are ton's of how-to threads on here), you really can't mess anything up. Just plan on spending a day doing the work, it's not a 15min swap, but it's not that difficult.
