2.0 LSJ Engine: HOW TO: DIY Dual Pass Endplate (pics inside)
#53
Also, beware of too much heat into the endplate. Castings like that tend to warp or crack with excessive heat. One reason why I don't like welding them for dual-pass applications.
#56
Safest bet is to grab them with some rubber-jaw'd pliers. They are very soft alumnium, and if you squeeze them hard at all they will dent in. Grab them as light as you can and turn them, once they turn a little they should pull right out, there's just an o-ring on the inside same as what's in the endplate.
#58
I was thinkin about making one of these but i have no welding tools or experience so i was wondering if you could do this without welding. Could i just drill a hole into one, tap some threads into it and then wrap the new piece im putting in in teflon tape?
#59
If you do it carefully, yeah. If you're trying to do it with a hand drill, good luck to you. The minimum size you have to drill for is 1/2"NPT which is a 23/32nds drill I think. If you are gonna do that, use some pipe sealant, Rector seal or similar, rather than teflon tape.
#62
From intake manifold to head is about 18lbs I believe, nothing serious. Good and tight by hand with a 1/4" ratchet will be plenty. The lower support bolt can be pretty tight, but don't get carried away on the flange bolts.
#67
How do you exactly take off the intake manifold? I remove all 5 bolts and 2 lugs but it doesn't come out. I tried to pry it out but its to uncomfortable to put a screwdriver between the block and the manifold.
#69
I just realized that previous owner did a dual pass on my car. He drilled tapped into the manifold and whatever he used to hold the connector in place wore out and i can pull it completely out. Is there a way I could put something back on it to hold it place for at least an immediate fix? School is almost over but until then i dont really have time to take off the endplate and properly weld or whatever. So what do you guys suggest? Heres a pic to get an idea of what he did....
#74
[QUOTE=juice3;5734801]I just realized that previous owner did a dual pass on my car. He drilled tapped into the manifold and whatever he used to hold the connector in place wore out and i can pull it completely out. Is there a way I could put something back on it to hold it place for at least an immediate fix? School is almost over but until then i dont really have time to take off the endplate and properly weld or whatever. So what do you guys suggest? Heres a pic to get an idea of what he did....
Looks like you have a JB weld dual pass
