Appearance: How To - Install and Aim NEW Projectors
Old 04-24-2008, 05:17 PM
Austyn_Balt's Avatar
Also one of my LEDS has already burnt out, where can you purchase new ones from?
Old 04-24-2008, 06:39 PM
DoubleLP's Avatar
I have no idea. I would be getting in touch with the company you bought them off of and see if they can replace the whole headlight under warranty. Usually there is a 30 day warranty on most stuff.
Old 04-26-2008, 06:15 PM
neodude101's Avatar
I wonder how hard it would be to open them up and modify the shield on the projector to minimize that flare up on the right side and make the output a little more flat.
I have halogens in mine now, and I'm wanting to get HIDs, but I don't want to blind people in their mirrors when I'm overtaking them (I do a lot of highway driving).
Old 04-26-2008, 06:19 PM
DoubleLP's Avatar
Most of that flare up is from the lines that are on the main lens itself.
Old 04-26-2008, 06:23 PM
KillerBee's Avatar
Those look good. The only thing i hate about the aftermarket projectors is adjusting them to make the light work good. I mean i did mine before but i just hate it personally. But they look amazing
Old 04-26-2008, 06:26 PM
neodude101's Avatar
I'm not talking about the scattered light on the left and right side of the road (the stuff that's usually way off in the ditch), I don't think that's too big of a problem. I mean the actual shape of the cutoff itself, how the light from each lens flares up to the right instead of being straight across.
I'd like it to look more like this:
and less like this:
If the cutoff doesn't throw light up so much on the right, then those lines on the outside lens itself shouldn't be too much of an issue, I don't think. I think they scatter the light horizontally, not so much vertically.
Old 04-27-2008, 06:59 PM
Nighthawk243's Avatar
The CCFL Projector lamps are ECE cutoff rather than the Z cutoff of the first and third style.
Old 04-27-2008, 11:36 PM
DoubleLP's Avatar
As Nighthawk243 said, they are a different cutoff on these lenses then the Gen 1 projectors. The ONLY way you could change that is by changing the shield inside the projector or putting different projectors in. Either way....it would be a lot of work.
Old 04-28-2008, 12:35 PM
neodude101's Avatar
Oh, I know that they're a different cutoff... and I was talking about modifying the shield. You know, that part where I said:
Originally Posted by neodude101
I wonder how hard it would be to open them up and modify the shield on the projector...
I figured it would be a lot of work, I just didn't know how much. You obviously have to take the back off, then probably dismount the projector (if that's even possible with these), open it up, then do something like this:
http://www.houseofthud.com/cartech/hids/
It was just a thought. I don't really want to screw them up trying, though.
Yeah, too bad it's good for Halogens, but not so much for HIDs.
Old 04-28-2008, 04:04 PM
DoubleLP's Avatar
I had HID's and took them out because the cutoff is more predominant with the HID's then with the Halogens.
Old 04-28-2008, 07:00 PM
  #36
neodude101's Avatar
That's what I was worried about. I don't really want to get people pissed off at me when I go to pass them.
Did anybody flash their brights at you or anything?
Old 04-28-2008, 07:09 PM
  #37
DoubleLP's Avatar
Nope not at all.
Old 04-28-2008, 07:12 PM
  #38
neodude101's Avatar
Okay, well that's good, I guess. So why did you take them out, exactly? You didn't like how predominant the cutoff was?
Old 04-28-2008, 07:51 PM
  #39
ViSiONZ's Avatar
I've been flashed once. But I know when I'm passing cars at night I'm blinding the people on the right. Considering their whole car lights up... lol. Oh well. I'm not taking my hids out. I can see a lot better with them installed, plus they look nice. Although, these projectors with just the halogens in them have really good light output too.
Old 04-28-2008, 08:28 PM
  #40
DoubleLP's Avatar
That is one reason, also I wanted to have my DRL's back on on the highway here. There are some stupid ass drivers out here. I can always put them back in. The ballasts are still in place and it would take me all of 5 minutes to hook them back in.
Old 05-05-2008, 08:00 AM
  #41
srcobaltss's Avatar
what the hell is this "cut off" we should be looking at?
Old 05-05-2008, 10:54 AM
  #42
DoubleLP's Avatar
When you are facing a wall or any other object, the light from the headlight is "cutoff" at the top so that all of your light that is from your headlight is focused on the bottom half of your view and is not leaking anywhere. That is why they are called "projectors" in that they are projecting the light downwards to give you the most light possible where you need it the most.
Old 05-09-2008, 02:58 AM
  #43
Also the purpose of the cutoff is to help avoid blinding oncoming drivers. When properly aimed, the light cutoff will be below the sight line of oncoming drivers. That way you're still getting light out there, but its not directly hitting the other drivers in the face. With reflector housings, there is no sharp cutoff, so if you would put a HID system into the stock reflector, you'd be dazzling other drivers with it.
Old 05-11-2008, 03:45 AM
  #44
spyvspy2k's Avatar
I have the same pair of 2nd gen lights but I'm getting 2 cut off lines. The passenger side light is visibly faint than the driver's side. Should I continue to adjust until they meet in the middle? Thank you in advance for the help.
Old 05-22-2008, 11:43 AM
  #45
trent_ky's Avatar
i just ordered these projectors...still havent decided if i want to get an hid kit too...what do you guys think?
Old 05-22-2008, 07:24 PM
  #46
ViSiONZ's Avatar
Are you aiming them against a wall from about 20-25 feet away?
Old 05-23-2008, 03:07 PM
  #47
neodude101's Avatar
http://www.danielsternlighting.com/tech/aim/aim.html
This should help out. Follow the rules for ECE headlight aiming.
Old 05-26-2008, 01:27 PM
  #48
Whitty's Avatar
how do u wire the halo lights ? or is that somehow controlled through the stock plug as well ? how do u turn just the halos on ? (I am really considdering a set of these but want some stuff cleared up first )
Thanks in Advance!
Old 05-26-2008, 01:38 PM
  #49
DoubleLP's Avatar
Depending on what set of headlights you get, the halos will be either wired in on you will have to wire them in. On the 2nd gen lights (as I have on my car) the halos are wired into the plug...so no wiring is needed. On the 1st and 3rd gen you have to wire them in.
Old 05-27-2008, 07:57 AM
  #50
Whitty's Avatar
dumb question though... how do you tell what gen you are getting say on ebay ? also if they are wired in (i want them to be (easier)) how do you turn just them on ? or are those your daytime lights ?
Quick Reply: Appearance: How To - Install and Aim NEW Projectors
