Appearance: How To - Install and Aim NEW Projectors
Old 07-03-2008, 04:30 PM
  #101
TSweet88's Avatar
why, wut u planning
Old 07-03-2008, 04:31 PM
  #102
steddy2112's Avatar
I think it looks better with the side markers as the DRL
Old 07-03-2008, 06:37 PM
  #103
berto's Avatar
I Would Make The Fog Lights Match The Halo's
But Thats Just Me
Old 07-03-2008, 10:40 PM
  #104
Renesis's Avatar
Originally Posted by TSweet88
go like...a couple pages back
for the CCFL yeah I know that my question is in the first sentence..
a way of disabling the amber parking lights and have them only be on when they're used for flashing?
Old 07-11-2008, 08:58 AM
  #105
jay99's Avatar
i already have my projectors in, is there anyway to AIM my headlights w/o removing my headlight again?
Old 07-11-2008, 09:39 AM
  #106
DoubleLP's Avatar
Which generation of headlights do you have?
Old 07-16-2008, 12:02 PM
  #107
csementuh's Avatar
I finally got my 1st Gen Projector aimed pretty good with my 6000K HIDs.... I do have 2 questions though...
I aimed them 25 feet from the garage door, and my cutoff was damn near perfect. But when I backed up, I noticed my "z's" in the cutoff spread apart and widen out when in plain sight. Then when pulling closer to the door the cutoff got closer together. Is this normal? Or do I need to aim them farther back so the ending cutoff is perfect? (not at 25 ft)
Also I made my cutoff about 6 inches up from the center of the lights at 25 ft. Most things I have heard was to make them slightly LOWER than the center of the lights... I can see great now at night, but do you think I am going to be blinding people? I have not gotten flashed yet, but I just wanted some opinions on this. Standing in front of the car the light is not blinding bright, in fact it kind of just washes the road in light instead of focusing it.
Thanks for the info!
Old 07-20-2008, 12:15 AM
  #108
Nighthawk243's Avatar
Originally Posted by steddy2112
So the 07+ that have the DRL as the highbeams...what do they do on these projectors
DRL's on 07+ are actually the low beam circuit. So if you do have the DRL's on, it'll be on the low beam projector circuit (I've seen it).
Now, if you do not want DRL's, you can simply remove the 10A fuse marked DRL from the Engine bay fuse box. It will kill your DRLs and it will not thow any lights on the instrument cluster. I pulled the DRL fuse since I have HID and did not want them igniting all the time.
Pulling the DRL fuse WILL NOT in any way affect your Auto Lamps. They will still turn on when it gets dark enough to trip the light sensor or when you engage the windshield wipers.
The beam difference will be noticable after 25 feet. Light travels in a linear way, so if you would draw a line from the center axis point of the light (Roughly the bulb) and drew it to the cutoff center point on the wall, and then extended that line, it would continue and you could get an idea of where it would be at 50ft, 75ft...etc. You're limited by physics, and there isn't much you can do about that since it would be impossible to reverse your car away from the wall WITHOUT it moving either a tad left or right which will throw off your aim a tad. Your aim is assuming there is no left/right deviation when moving back to the 25Ft mark.
As far as the second paragraph, same thing applies. If your lights are not centered (As you mention, they're actually 6 inches higher) the light will travel in that same line, and angle, which will probably be much higher than the 6 inches above centerline at distance. To some vehicles, it may not be bad enough to notice (Truck drivers will rarely get blinded and will only flash if your lights are royally screwed up, but expect car drivers to get quickly pissed off.)
Another thing to keep in mind too when aiming lights is "Will I ever blind a cop?". The LAST thing you want to do is blind an oncoming officer, because 9 times out of 10, he will spin right around and light you up. My locals hand out quite a number of citiations for a driver either having poor aiming or forgetting to turn their high beams off. The first thing I hear over the scanner too is "<badge #> to county, I have a <insert vehicle here> that just blinded me. Stand by."
Last edited by Nighthawk243; 07-20-2008 at 12:15 AM. Reason: Automerged Doublepost
Old 07-21-2008, 12:31 PM
  #109
csementuh's Avatar
Thanks a lot for posting that info. I knew I had my lights aimed pretty good, although a little high. I just wasnt sure how the cutoff should be at distance. As far as the lights being too high, they seem to be pretty good as of now. Visibility is great, and I still have never been flashed for the lights. Also nice to see some more people on here from around the Pittsburgh area!
Old 07-21-2008, 04:02 PM
  #110
jay99's Avatar
http://cgi.ebay.ca/Chevy-Cobalt-05-0...ayphotohosting
what ever generation these are.. i have these headlights
Old 07-21-2008, 10:36 PM
  #111
Those would be the third generation.
Old 07-22-2008, 08:42 AM
  #112
jay99's Avatar
are these easy to adjust/align?
Old 08-24-2008, 04:14 PM
  #113
liljone's Avatar
for the 1st gens owners reading this 2nd gen how-to. here are the **** you need to use to adjust your lights (way different then gen 2):
they are 2 sliver looking **** right under the low beam boot.
you got to remove the whole headlight to get to them:
since this how-to was for 2nd gen I had to find the **** the hard way. hope you guys find this helpful and save troub I went to finding the damn ****.
Old 09-09-2008, 01:41 PM
  #114
Renesis's Avatar
anyone found a way of rewiring them or doing something when the halos/CCFL stop working?
I mean they cannot have burned down in a few weeks/months and everyone seems to have problems with them so I guess it's down to bad wires? there must be something to be done..
one one side the CCFL bar died like 2 months ago and today I lost all halos the only thing still working are the LED's
which wires should I check out?
Old 09-09-2008, 06:04 PM
  #115
DoubleLP's Avatar
I would check first for corrosion in any of the plugs. If there is, use some contact cleaner to clean them out.
If that does not work....I don't know what to tell you.
Old 09-09-2008, 06:10 PM
  #116
berto's Avatar
Any Links To Where I Can Find New Ones??
Old 09-09-2008, 06:11 PM
  #117
DoubleLP's Avatar
E-bay. Some of the vendors on the site have them as well.
Old 09-21-2008, 11:33 PM
  #118
blackSS09CA's Avatar
question for anyone who has the 1st gen projectors.... how do you get HID into these... this is a picture from home im not infront of these lights so i really cant get a good understand how you put the HID bulb in it.... heres what im seeing
https://www.cobaltss.net/gallery/fil...img00405_1.jpg
Old 12-15-2008, 08:14 PM
  #119
DBewley925's Avatar
Hey.... My projectors didnt come with the plug in part for the wires... is that necessary? or is there a way i can get around that?
Old 12-18-2008, 05:45 AM
  #120
If you're using the first or third gen projectors, you use the wiring harness that was used for your OEM lights.
Old 12-18-2008, 10:43 PM
  #121
DBewley925's Avatar
I found out i could use the stock ones... But where do i get a plug for the H1 Bulbs??
Old 12-19-2008, 05:09 AM
  #122
There should be a 9007 plug that you can plug into that goes to the H1's.
Old 12-19-2008, 01:22 PM
  #123
DBewley925's Avatar
Do you know where i can get that plug?
Old 12-20-2008, 10:24 AM
  #124
Xmetalhead2003X's Avatar
Quick question, I have 1st generation projectors and being installed into a 2008. I was wondering if I should purchase the DRL cancelling unit or can I pull the DRL fuse without any reprocussions? Another question I was wondering which would be easier, to buy a 9007 HID or the H1 kit? I know its some minor electrical and physical differences of the systems but was wondering which is the optimum and less of a hassle to setup.
Also, with 35W ballasts VS 50W, which would be better for the job?
Last edited by Xmetalhead2003X; 12-20-2008 at 10:24 AM. Reason: Automerged Doublepost
Old 02-23-2009, 12:43 AM
  #125
AdamJay's Avatar
rehost cutoff pic please?!?!?!?!!!
Quick Reply: Appearance: How To - Install and Aim NEW Projectors
