Appearance: How To - Install and Aim NEW Projectors
Old 02-23-2009, 12:57 AM
  #126
cobaltspeced's Avatar
i took my 3rd gens out and went back to stock. did not like them.
Old 02-24-2009, 07:07 PM
  #127
cobaltss1969's Avatar
why didnt you like them???
Old 02-24-2009, 08:13 PM
  #128
Nighthawk243's Avatar
Originally Posted by DBewley925
Do you know where i can get that plug?
Ebay is a good bet.
Old 02-26-2009, 12:43 PM
  #129
the beam was to narrow. didnt light up the road better then the stock lights. maybe i didnt have the beam focused right or not but i couldnt figure out how to adjust it. on my girls 2008 Tiburon, she has factory projectors and the beam was perfect.
Old 03-10-2009, 05:54 PM
  #130
riko540's Avatar
what happened to the pics? Its kinda hard to do this without them.
Old 03-14-2009, 02:57 PM
  #131
RedSS50's Avatar
Thumbs up
^^^^^^^ x several
Old 03-18-2009, 11:05 AM
  #132
06'BaltLS's Avatar
im not sure what gen projectors i have, but i was wondering how to wire up the halo rings.....i see a white wire and black wire for them.....i also see a few sets of a red wire and black wire for the small LEDs in the bottom of the headlight.....all i want to do is hook up the halo rings.....
Old 03-22-2009, 06:34 PM
  #133
riko540's Avatar
Here is the how-to I used for wiring everything up.
https://www.cobaltss.net/forums/how-guide-43/how-wire-up-halos-projectors-43677/
Old 03-22-2009, 09:06 PM
  #134
06'BaltLS's Avatar
awesome, thnx riko540
Old 03-22-2009, 09:28 PM
  #135
riko540's Avatar
no problem
Old 08-23-2009, 02:55 AM
  #136
WhiteFiver's Avatar
Did this tonight. Helped a lot! I was lost too without p8ictures, until I saw someone's post that described what each screw did.
Old 11-14-2009, 01:07 PM
  #137
Camaro33's Avatar
helpful post. i am getting 6000k hids for my gen 3 projectors. I have to aim them.
Old 03-15-2010, 05:09 AM
  #138
hawkeyez's Avatar
How do you aim the third gen projector headlights???
Old 03-15-2010, 06:25 AM
  #139
Gestapo007's Avatar
little silver knobs behind the low beam. The one closest to the side of the car is up and down. Turning it left will aim the light up, turning it right will aim the light down. I used a 1/4" stocket wrench with a tiny socket to turn it. The Silver knob on the inside of the headlight is the left and right adjustment.
Old 04-03-2010, 11:20 PM
  #140
drop-n-destroy's Avatar
Bumping this thread to get the pictures fixed! I need to know how the projectors need to look when properly aligned. I have 4th gens and need to align them
Old 04-04-2010, 03:15 PM
  #141
rossshady120's Avatar
Originally Posted by Nighthawk243
Also the purpose of the cutoff is to help avoid blinding oncoming drivers. When properly aimed, the light cutoff will be below the sight line of oncoming drivers. That way you're still getting light out there, but its not directly hitting the other drivers in the face. With reflector housings, there is no sharp cutoff, so if you would put a HID system into the stock reflector, you'd be dazzling other drivers with it.
they do thats one of the reasons i want projectors but more that i got HIDS and i cant really see the road.
here are some pics my 8k's vs stock GTI
Old 04-17-2010, 03:43 PM
  #142
cardinalzboi's Avatar
dang i NEED those pictures!!!!
Old 08-21-2010, 03:09 AM
  #143
zerosk8ter83's Avatar
whats the point of this thread if you cant even see the dam pictures >_<
Old 09-23-2010, 03:03 PM
  #144
tanelk's Avatar
someone needs to post pics of how its suppose to look when aimed cus i got hids in my gen 1 and i still cant see **** on the road.
Old 11-17-2010, 02:40 AM
  #145
brainchasm's Avatar
This.
Thanks for this OP! It was super easy, and I'm aimed properly now with my Gen4s.
I would likely have tried it sooner or later (figured that thing was for aiming), but it's a lot easier to get motivated to do it when you know for sure!
Old 12-16-2010, 12:39 PM
  #146
1fastSSBalt's Avatar
You need to upload the pictures again please. I would appreciate it just to see the cut off and everything.
Old 12-16-2010, 12:55 PM
  #147
sacrdandprofne's Avatar
I was told that, for 3rd gens, you had to turn BOTH knobs equally in the same direction for up or down. Is that not true?
If one knob really is for up/down and one is for left/right, that would explain why I've had such a bitchy time aiming these things.
Old 03-27-2011, 11:40 PM
  #148
maassizzle's Avatar
It is impossible to find a clear answer or picture on how to aim the headlights, but it seems that everyone has figured it out. I am not sure what "little silver knobs" they talk about.
Old 04-05-2011, 12:15 PM
  #149
Tropicaljoe's Avatar
Is this good for retros?
Old 04-05-2011, 12:18 PM
  #150
bump for pictures DAMIT!
Quick Reply: Appearance: How To - Install and Aim NEW Projectors
