Appearance: How to Install LED lights into your reverse lights
Old 02-28-2008, 12:09 AM
  #76
kirby's Avatar
Originally Posted by origami78
This should help. Parts used 2 20K ohm adjustable Resistors and 4 1N4001 Diodes.
With the adjustable resistors you can change the brightness of the lights when the parking lights are on. the higher the resistance the more dim they will appear. If there is not enough resistance when you hit the brake or turn signal there will not be a visible change in the brightness.
is there any way i can put 2 halo rings in the reverse lights and run the wires to the same place the led wire goes in this pic? that way i can adjust the brightness and have them work as brake/turn signals as well right?
Old 03-03-2008, 09:46 AM
  #77
origami78's Avatar
I don't see why it would not work the Halos use LEDs don't they?
Old 03-05-2008, 08:13 AM
  #78
EmperorJJ1's Avatar
lol a year later and im still amazed origami
Old 03-05-2008, 09:51 AM
  #79
Kibosh3's Avatar
ya...thats wat i plan on doing...halo rings instead...no muss-no fuss...and solid light throughought the housing
Old 03-05-2008, 09:58 AM
  #80
ViSiONZ's Avatar
Great write up! I'm trying this for sure in the spring!
Old 03-07-2008, 11:15 PM
  #81
Viper33884's Avatar
Pretty nice write up, I wanna do something to my center's....some reason they just don't look right sitting there not lighting up.???
Old 03-12-2008, 12:47 AM
  #82
kirby's Avatar
has anyone done this with halo rings before? should i get the ccfl rings with the ballasts or just normal halos with 2 wires comin from them?
im using 1, 80mm n 1, 100mm in each tailight btw.
whats the average price for halo rings? the ones on ebay are like $45 a set
Old 03-16-2008, 03:04 PM
  #83
yellowltcoupe22's Avatar
origami you think you could build me a set up like you have so the would be dimmer on runnin lights and get brighter when the brakes are applied or the blinker is on? i would pay good money for this to happen..
Old 03-16-2008, 04:20 PM
  #84
EmperorJJ1's Avatar
im intersted as well
Old 03-18-2008, 09:18 PM
  #85
bump.. i would really like to get this setup before i just put leds in mine..
Old 03-19-2008, 01:19 AM
  #86
EmperorJJ1's Avatar
lol no offence but i asked a long ass time ago (post 66)and it never really happened. not saying it wont but just dont want u to put off ur project for too long
Old 03-19-2008, 01:22 AM
  #87
jefferyss's Avatar
looks good
Old 03-19-2008, 09:20 PM
  #88
lol yeah i seen where you had asked him bout makin you one but figured i'd ask anyways. o well i guess. my leds are on there way so i'll be doin mine in the next week or so.. it'll be somethin like jakeu's but imma put bout 14 or so leds in each one of mine..
Old 03-20-2008, 03:13 AM
  #89
EmperorJJ1's Avatar
lol i hope ori can get u some done before then bc that would be awesome...
Old 03-20-2008, 11:48 PM
  #90
yeah it would.. if he cant do em for me imma do some studyin on how to wire em up to work like dual filament bulbs. it cant be to hard to do. just need to do some research on it before i try it..
Old 03-21-2008, 03:20 AM
  #91
EmperorJJ1's Avatar
an easy fake way to do it is try and fit a crazy amount like he did (20 or 22 i forget) then wire up half of them to the running wire with a bigger resistor and the other half to the brake wire with a smaller resistor. This would give u full light up when u brake and an obvious difference when u do so. Only **** up will be turn signals while braking. there should be a bit of difference but it wont be as prominent
Old 03-22-2008, 04:45 PM
  #92
can any one tell me how ori's set up works? i've ordered the stuff that he used and was wondering where the two wires go after they come off the adjustable resistors? if im thinkin right then they will bout tie into the postive side of the led so that it dims them untill you hit the brakes and they then go full power.. some one tell me if thats right please...
Old 03-22-2008, 06:50 PM
  #93
EmperorJJ1's Avatar
no idea pm him and see if he responds
Old 04-01-2008, 01:49 PM
  #94
kirby's Avatar
im using led strips that have a + and a -. which wire should go to the resistor and which should go to tha yellow or green wire? does it matter?
Old 04-01-2008, 07:54 PM
  #95
the resistor goes on the positve side and the yellow wire does to.. i think your led stripe already has a resistor built in though and addin another one will just make em really dim without gettin bright at all. ori's set up is made for leds that hasnt had any resistors added yet (i.e. led strips and pre-wired leds).
Old 04-02-2008, 07:46 AM
  #96
kirby's Avatar
im just using the adjustable resistors to change the brightness so i can have brakelights and turn signals
Old 04-02-2008, 07:29 PM
  #97
that may work then.. let me know how it works out for you..
Old 04-08-2008, 09:38 AM
  #98
origami78's Avatar
The way I setup the circuit you hook it up to the positive of the LEDs and the negative connects to ground either the black wire or the car frame. Both the Brakes and turn signals work like the taillights.
Old 04-08-2008, 04:37 PM
  #99
kishi's Avatar
Are all 4 light always on like in a corvette or just when hit brake?
Old 04-08-2008, 10:28 PM
  #100
they will all be on any time the lights are on and will get brighter when you hit the brake oruse the turn signal.
Quick Reply: Appearance: How to Install LED lights into your reverse lights
