Appearance: How to Install LED lights into your reverse lights
#127
yea I got it, didnt realised my father had a test light. i finished one light. What a pain in the ass omfg. This is by far the biggest pain in the ass project ever lol. The sealant around the housing sucks ass. Tried everything then finally got it b4 I busted the hell out of the lens. 2nd one was a little easier after i put it in the oven after i dremeled and drilled then i cooked and pryed till it seperated. lol
Finsihed mine tonight. OMG pain in the ass. hacking up reverse lights is not for the faint hearted but i finally did it, wired it up to parking lights. Dont have resistors or **** because I dont want them as turn signals. The uneven blinking bothers me a little and I just like the always on thing. It does kinda illuminate the center part but since my lights are heavily nightshaded it looks bad ass.
And I got 9.5" LED strips wich were too short so I had to cot and sodder and ugh. nightmare lol. PIC!
#128
Well I put 32 LEDs in my 3rd brake light now the cruise don't work. IDEAS???
For anybody that's interested.
http://www.superbrightleds.com/led_prods.htm
#129
Pretty good stuff gestapo. Did you do that with an LED strip? I was thinking about doing my third brake light with a LED strip. I just gotta dive into the backup/rear lights how-tos. Im a pro on the headlights, lol!
#130
If you haven't been to this site yet try it. It's got every kind od LED you'll ever need for automotive use.
#131
Yea it was with an LED strip. and look for a "Nighthawk LED 3rd brake light"
#132
A simple way to get an LED third brake light is to find an Impala in a junkyard (2000-2005 model) and take the third brake light from that, it uses an LED strip instead of bulbs. I have this installed and my cruise works fine.
As far as LED bulbs are concerned, I much prefer the selection from www.v-leds.com since their bulbs are quality products and haven't failed me yet.
#134
Thanks for everybodys help anyway.
#137
Like I said, I did some research and learned the 3rd brake light must be working WITH THE PROPER RESISTANCE. The LEDs have like zero resistance (acrually it is infinite resistance) so a resistor must be put in the circuit to simulate the resistance of the 3 incandescant bulbs. This is the page with the resistor you will need and at a price everybody can afford.
http://www.superbrightleds.com/cgi-b...gi?product=CAR
The item you want is the "RL650 Tail Light Load Resistor Kit".
It's possible the Nighthawk, which I can't find anywhere on line, already has the resistor built in? The only Mod Performance I found appears to be primarily a mod INSTALLER in which case they, hopefully, would know the resistor has to be in there.
If you want to let me be the Guinea pig on this, my resistor is on the way and I should have it installed this weekend and will post the results. I ended up putting my stock, butchered, lamp back on for the time being and with it the cruise, as expected, works fine.
#139
To answer your question directly. With the stock bulbs installed, with their associated 6 OHMs, the Cruise works. With NO bulbs, or with the LEDs only, both with ZERO (infinite resistance) OHM's, the Cruise DOESN'T work. Period!!
I've been looking for the "Nighthawk" lamp and/or "Performance Mod" and can't find either one. Got a link??
Ford and Chevy, obviously us different Cruise circuitry.
To"Gestapo007". Be careful with the resistors!! Small, 2 watt or less, like you find in Radio Shack will set anything touching them on fire. I tried a 5 watt wirewound and poped it the minute I touched the brake pedal. You need a HIGH POWER resistor like the one I referenced above. It is a 50 watt resistor and is made for this expressed purpose. Good luck.
#140
ok so you have your third brake light leds wired....why wouldn't you just put a 6ohm resistor at the end of the chain? that way leds wouldn't dim, and six ohms of resistance would be recognized.....
#141
It might work that way but LED sellers online tell you to put the resistor in parallel. I used to know all this stuff 40 years ago working on radar in the air Force and the Lunar model after. But I've been away from electronics since 1969. I stail remember a couple of formulas but not much of the theory. It's a bitch getting old!
#142
I did some calculations on the size of resistor I will need to dim the leds for when the brakes are not applied. The strips I'm using operate on 12 v @ 85 mA. I calculated the resistance of the strip from this information which I found to be 141 ohms. I then calculated the current draw at 9 volts by taking 9 volts divided by 141 ohms which yielded 63 mA. To calculate the resistor I needed, I took 12 - 9 divided by 63 mA and got 48 ohms. I don't think this is right however; seeing as how somebody earlier used a 20 K Ohm pot for their lights... help?
#143
http://www.superbrightleds.com/led_p...FQi_sgodlQ5KnA
http://www.superbrightleds.com/tail-brake-turn.html
Good luck.
#144
I think you're going about this the wrong way. LED's are meant to operate at a (ONE) design voltage. The light output is increased or decreased by adding or removing LED's the same way as having two filaments in a brake light bulb. One element for the running light and another for the brake light. Hence 2 wires going to it. The following links might help you. I know it helped me when I replaced the high level, third, brake light assembly with LED's. The cruise wouldn't work without 10W, 6 oHM resistors across the LED strip. The second link has the resistors you will need for EACH LED.
Good luck.
Good luck.
z28addiction
09-28-2015 12:03 AM
