2.0 LSJ Engine: How To Install Oil Pressure Gauge Into 2.0L LSJ
as for your question that is autometer phantom series gauge p/n 5727. its a short sweep electric gauge.
FYI we carry the autometer fitting 2278 at www.TurboTechRacing.com and keep them in stock.
has anyone installed thier oil psi sender on the side of thier block? i know i saw someone do it but i dont remember who....I have been trying to get that oil gally thing open but its some different kind of allen key its a star i believe and its hard as hell to open i cant get it..any advice???
One thing I would like to add is that you dont have to use the Oil Pressure Sensor port you can just pull off one of the gallie plugs on the head and use that as well it has the same bolt pattern and everything as the oil pressure sensor you just dont have to pull it off. I believe that the gallie plug is a t10 Star you can get the socket from any local auto parts store or Sears. Craftsman is my tool of choice.
Mechanical gauges are ok but you dont want to take a chance on that line coming loose in your car, and oil getting everywhere. Electric is the way to go.
Last edited by coopercharge; 03-15-2010 at 10:27 AM. Reason: Automerged Doublepost
#37
Great write up. I'd like to add an oil pressure gauge to my LNF also but before I replace the stock sending unit I'd like to know if that signal goes to the ECU and if it does what, EXACTLY, is it used for? I'm more inclined to use a different location. Just throwing that out there.
#39
I just did my dual pass and pheonalic spacer. Since I had the intake off, it was easy access to the oil gally ports so I didnt have to disconnect anything. I used the ZZP Oil feed to -4 AN fitting, then a #4 an Elbow and a oil line from Sumit to run to my aeroforce sensor that i mounted ontop of my supercharger shareing the same bolt with that sensor.
#40
Metric, I think H6,
Same as the SUpercharger I belive
#44
I have a writeup over here as well, little different but great for turbo cars.
https://www.cobaltss.net/forums/appe...onight-294335/
#45
#47
So I am thinking this to retain the stock sender as well as an aftermarket.
Thoughts?
OR ==============================
Fitting, Y, Brass, 1/8" NPT, 2 F, 1 M (am-2186)
Thoughts?
1/8" NPT Street Tee T Fitting for Brass Pipe Dual Female/Single Male: Amazon.com: Industrial & Scientific
#48
So the autometer and equivalent brass fittings are weak as hell. My Autometer 2278 adapter snapped after hand tight and 1/4 turn while wiggling the wrench off. Look into these to use as your adapter instead. Stainless steel and only a couple buck more than the autometer unit.
#49
so is there enough room under the intake manifold for the sender if its put in the oil galley plug? just doesn't seem like there would be a lot of room. And well will they take heat? I'm sure it gets pretty warm there on a SC car.
#50
However, from what I have looked at, the only way your getting it in is if the IM is already off.
I am going to put my senders in the back of the block and slide something like this over them to protect them and the wiring from exhaust heat
Blue Heat Protector Spark Plug Wire Boots 2 Cyl Dei Protect A Boot Equivalent | eBay
