2.0 LSJ Engine: "How To" Install OTTP's 4th Gen Heat Exchanger w/o Removing the Bumper
Old 10-14-2011 | 03:08 PM
  #76
great how to staged. i'm doing this tomorrow! so... sub'd! hey is the top or bottom line coming out of the back of the stock h/e the in or out hose?
so is it (on the back of the stock radiator)
top hose = in
bottom hose = out
or reverse?
Old 10-14-2011 | 03:18 PM
  #77
Staged07SS's Avatar
Administrator
Administrator
top hose = in
bottom hose = out
or reverse?
http://www.zzperformance.com/miscftp/HE%20routing1.jpg
Old 10-15-2011 | 11:41 PM
  #78
insylem's Avatar
Once the bracket locations are marked out, use a 3/8" drill bit to make the required bolt holes.
This may help some
How to Drill Hard Steel - YouTube
Old 10-16-2011 | 12:53 PM
  #79
insylem's Avatar
Originally Posted by meyers3261
how do we hook up the tubing?
Better question: How do we get the tubing to bend 90 degrees in a tight radius without kinking?
I couldn't get the holes exactly marked so they were slightly off, I had to oversize drill them with a step drill, and I still didn't get them perfect, but its physically instaleld now. I just have to route the tubing.
Why didn't they make the tabs for the mount to use the bumper panel connection. Replace the plastic body bolts with the cap bolts. That would have been WAAAAAAAAAAAAAAY eayser....
Old 10-16-2011 | 04:04 PM
  #80
insylem's Avatar
Originally Posted by insylem
I live in a hot climate (Southern Alabama)
Would this HE effect my air conditioning? And Engine Coolant temps? Since its in front basicly heating up the air before it flows through the condinser and the radiator?
YES!
Engine Cruise Coolant Tempature went from 180-185 to 185 - 190
Old 10-16-2011 | 05:27 PM
  #81
Staged07SS's Avatar
Administrator
Administrator
I had no issues with bending the hose. Mine is not bent at a 90. I gradually bent it out from the connectors on the heat exchanger. This prevented any kinks from happening.
I also oversized the holes in order to get perfect fitment, and ease of adjustment. Something I should have mentioned when I first made this thread.
YES!
It did not affect mine what so ever. Although in theory it should.
My cars ECT has always been around 170ish-175ish, and 180ish on hotter days. With or w/o the front mount heat exchanger.
Old 10-17-2011 | 06:42 PM
  #82
thanks for the how to. helped a bit.. i wound up cutting about an inch square out of the bumper plastic to fit it more flush.
Old 10-17-2011 | 07:58 PM
  #83
SylverSS/SC's Avatar
you shouldn't have had to cut the bumper at all
Old 10-18-2011 | 08:15 AM
  #84
Staged07SS's Avatar
Administrator
Administrator
I made my holes oblong, so I could further adjust the heat exchanger's placement. My heat exchanger sits perfectly flush to the bumper support/crash bar. You didn't need to cut anything out.
I wish you contacted me so I could have helped you out a bit more.
Old 10-18-2011 | 08:28 AM
  #85
insylem's Avatar
Talking
I did not have to do any cutting, though I did have to bend the bumper some to get it in, but it fits back now that it's in. I thought I *might* have to Trim the bumper abit, but that ended up not being nesscary. Would have been nice if they would have put the tabs so that you could use the same holes in the frame that the bumper plastic mounts to
But thanks, good write up. Helped me alot, since I didnt have a clue where to start. I needed to find a how to to drill steel, haha. But that guy's meathode (on a few posts back) didn't work with me because its too thin, it kept wanting to bend and then the bit drove in like a sheet metal screw, so I baught a Step Drill/ Unibit and that worked like a CHAMP!
Glad I had safety Glasses/goggles though.
Old 10-18-2011 | 08:32 AM
  #86
insylem's Avatar
Maybe because your in PA (according to your user profile) and I'm in Southern AL
Old 10-18-2011 | 08:36 AM
  #87
Staged07SS's Avatar
Administrator
Administrator
Ehhh....
When I installed mine it was one of the hottest summers in PA (95* almost every day for a month). No change.
Although, a hotter climate could def be the difference.
Old 10-18-2011 | 09:05 AM
  #88
insylem's Avatar
Ehhh....
Maybe mine was just because I had bugs on the radiator and havnt really watched my coolant temps in the immediant days up to before the install. I hope theres nothing wrong with my engine thats makeing it a little warmer, even though its still withen limits.
It was about 90 when I drove it with the HE on, and plumbing not hooked up, Ill try to get it this week if I can find some time to use the lift onbase. Right now the holes are plugged with a rang and some zip ties.
Old 10-18-2011 | 09:13 AM
  #89
Darn well really it wasn't much and it wont even be noticeable from the outside later on if i ever take the h/e out, it was just that the angle of it seemed like the bottom was angled towards the rear, and the mounting bracket was too far off the bumper so idk... f***in cut that ****
Old 07-06-2012 | 03:40 PM
  #90
c130aviator's Avatar
Here is my heat exchanger install. This was easeier than the stupid carbon creations hood that got the mounting holes wrong. Anyway. This is the OTTP unit and there are a few things to keep in mind. Get a 1/4" Brass plug. The part number at orilleys is in the picture at the bottom. And hose routing is a pain, remove the driver side radiator support to help with removing the hose on the stock heat exchanger, that took me forever and I ended up cutting off the stock hose clamp with a angle grinder.
The OTTP HE weighs in at 8 lbs 10 oz.
Removing the forward two plastic push pins allows you to get the HE up and in to the bumper to allow for placement and to mark the holes. Its a perfect fit, almost like the bumper was designed to allow its placement on all sides.
Use a step bit to drill the holes, its a lot easier, can be had at harbor freight for less than 10 bucks for 3 of them.
You will need to pop the top four push pins from the radiator support and this will allow you to get your hands down into tighten the bolts. I used a 14 mm wrench and a TORX 50 bit on a 3/8" drive wratchet make sure you have the large TORX before you start the install.
You can see this sits higher than the lip of the bumper, no worries of scraping. I removed the black air dam from below the radiator, it comes off with two push pins as well. This whole car is held together with plastic pins...
This is the part number and the part needed to replace the lower radiator drain valve. The OTTP unit sits low but I bought a 1/4" NPT plug from orilleys for 3 bucks. You can see the radiator doesnt sit lower than the bumper now. No worries of it scraping.
Now this was the hardest part of the install, the radiator bolted on in less than 30 minutes. Getting the stock hose off the lower stock HE was the biggest problem. I cut it off with an angle grinder.
This pic is the new hoses that come with the OTTP unit. it includes clamps and bolts, everything you need.
At the bottom right of this picture is the radiator support, remove the 3 bolts and yet ANOTHER plastic push pin to get at the hose clamp. Took me an hour on this one part. Frustrating... The rest were just push on the hose and clamp. Easy enough. The routing can be found here. http://www.zzperformance.com/miscftp/HE routing1.jpg or http://www.zzperformance.com/miscftp/HE routing2.jpg
Old 07-07-2012 | 07:26 PM
  #91
insylem's Avatar
Hey not only do you have the same color car as me, but you also have the same color jackstands!
Old 07-28-2012 | 05:22 PM
  #92
dtabbs's Avatar
Originally Posted by sjc0013
I think we are missin each other here staged haha. Im saying to press the white orifice into the hose first, then to put it onto the brass fitting. Youre saying that I need to press the orifice into the bottom of the brass fitting, then screw the fitting in, and go from there.
This i what I'm looking at. So the fitting gets screwed in, then the orifice pushed up into the hose, and then the hose pushed down onto the fitting. I tried to fit that orifice in the bottom of that fitting like you said, but theres no way thats gonna fit, its just simply too big.
Since this thread has been derailed so far off track and there are pictures here I am going to ask. Is there a reason you guys are using a straight fitting instead of a 90° fitting?
Old 07-28-2012 | 07:05 PM
  #93
never thought the thread derailed...
anyway, mine is only a a few weeks old and is now for sale. I went turbo...
Old 07-28-2012 | 07:17 PM
  #94
boostbalt's Avatar
Did you plumb it in without removing the front fascia? If so, how the heck?
Old 07-28-2012 | 07:46 PM
  #95
boostbalt's Avatar
When I remove the hoses from the stock H/E out line and the Pump's in line, how much coolant should I expect to come out? Also, should the car be jacked up when I do this to drain all the fluid out? Or is level fine?
I'm a bit confused about refilling, would I refill the stock H/E and the new H/E through the same filler tube in front of the radiator?
THanks!
Old 07-30-2012 | 08:08 AM
  #96
Staged07SS's Avatar
Administrator
Administrator
The thread is far from derailed....
Other members posted their install based off of my how to.
Anyways, Redlines need to use a 90 degree fiting due to clearance issues. Cobalts do not have this clearance problem.
Old 01-03-2014 | 12:14 AM
  #97
colbyg's Avatar
Would this work with the ZZP S2 H/E?
Old 01-06-2014 | 06:12 PM
  #98
Staged07SS's Avatar
Administrator
Administrator
Yes, it should.
Old 06-03-2014 | 05:19 AM
  #99
Empty Pockets's Avatar
subd
05-28-2022 04:47 AM
DarrenGC
12-24-2021 02:55 PM
justinchinn
10-02-2015 01:18 PM
Delta coupe
09-30-2015 09:11 AM
n20saturn
09-30-2015 01:26 AM
