Appearance: HOW TO: TINT YOUR LIGHTS in 10 steps
Old 05-31-2006 | 03:34 AM
Beck's Avatar
EDIT: FINAL PICS ADDED --- Also added pics of Braking during the day and at night with the tinted lights
Alright ladies, today I’m going to teach you how to tint your friggen lights so you will stop asking how! This can be applied to tail lights, side markers or even to add eyelids to your headlights. I strongly recommend removing the lights from the car before tinting and I would not recommend this strategy for tinting your windows. Make sure you’re doing this in a well ventilated area so you do not die from the fumes.
Materials Needed:
1. Nightshades or Krylon Crystal Clear Translucent Spraypaint
2. Duplicolor Clear Coat
3. 1500-2000 Grit Sandpaper (optional)
4. 600 Grit Sandpaper
5. Paper towels
6. Painters Tape
7. Soapy sponge
8. Ventilated area.
forums//showthread.php?t=22207"]Click Here to See the Differences Between the VHT Nite Shades and the Krylon Crystal Clear Tint Spray[/SIZE]
Step 1: Using the Soapy sponge scrub the lights clean. Wipe all traces of the soap off with a damp rag. Be sure not to get the electrical components wet.
Step 2: Using the 600 grit sandpaper, evenly sand the light in the desired areas you wish to tint.
Step 3: Use the wet rag to wipe away any plastic debris removed during the sanding process.
Step 4: Tape off any areas on the lights you do not wish to be tinted. (Not applied to this specific tinting session) The use of a sharp razorblade works wonders when making precise cuts.
Step 5: Tape a paper towel or newspaper or whatever (or just jam it through the protruding plastic apparatuses such as I did) around the parts/pieces of the lights you do not wish to be painted (i.e. the back housing of the lights)
Step 6: Place the lights in an area you don’t give a **** about (large cardboard box or lying newspaper down works well if you don’t want to get paint on your floor/table)
Step 7: Shake dat ****…. Shake your tint spray for about a good minute or so to make sure the spray is evenly mixed and not pasty. Once you are done making crude gestures with the can, you may now apply the tint.
Step 8: Hold the can UPRIGHT… approximately 12-15inches away from the lights and with a steady fanning motion apply a basic coat. Don’t go too thick on the coats. After you are done with your first coat, the lights should look something like this:
Step 9: wait approximately 15-20 minutes between each coat and sand with 1500-2000 grit sandpaper… if desired…. To remove any imperfections in the paint job (dust specs, shitty paint job, etc.) Apply as many coats as you wish until desired darkness is reached.
Step 10: after letting the final coat of nightshades dry for 30 minutes or so, apply clear coat in the same manner as the tint spray. I’d recommend a good 2-3 coats of clear coat. Let the lights dry for a few hours after the process is complete. You may now reinstall your lights!
Brake lights during they day:
Brake lights and reverse lights at night
The clearcoat allows you to wax the lights just as if they were part of the body and adds a nice shine.
Note: tinting your taillights and side markers is most likely illegal in your state/province. Do not come bitching at me if you get pulled over and issued a fix it ticket.
Old 05-31-2006 | 03:52 AM
REIGN SS's Avatar
Original Hayden Fanatic
nice write up
Old 05-31-2006 | 03:55 AM
jasonaudio's Avatar
GREAT write-up! Nice work
Old 05-31-2006 | 04:07 AM
Beck's Avatar
thanks guys, i'll have pics of the lights on the car tomorrow.
Old 05-31-2006 | 04:12 AM
05BlackCobaltSS's Avatar
looking good...
Old 05-31-2006 | 01:44 PM
Beck's Avatar
K here's the installed pics... These are in DIRECT SUNLIGHT but you can still see the red glare to them. when not in the sunlight they look pure black. looks sweet.
Old 05-31-2006 | 05:07 PM
spencer's Avatar
looks good bro...are you going to do the outside lights too?
Old 05-31-2006 | 07:33 PM
Beck's Avatar
yea i am as soon as i get a nother can of nightshades, im running low on my other lol.
Old 05-31-2006 | 07:54 PM
biniecki's Avatar
i did all 4 lights in the back and the 2 reflectors with just one can
Old 05-31-2006 | 08:24 PM
tiny's Avatar
looks good, also, those inner lights are used for reverse lights only, i wouldnt plan on doing this if you use your reverse lights to see at nighttime
Old 05-31-2006 | 08:26 PM
Beck's Avatar
yea i still have some left im just not sure if it is enough. i dont want to start on them if i cant finish them lol. i did a lot of coats.
Old 05-31-2006 | 09:18 PM
JackD's Avatar
If you put less coats of the night shades on will you get less of a tent?
I want just a touch of a tent yours are darker than what I want.
Old 05-31-2006 | 09:21 PM
Beck's Avatar
of course. you could really just make them dark red if you wanted.
Old 05-31-2006 | 09:23 PM
Ljavy17's Avatar
I dont like it.
PuSha050's Avatar
yup exactly correct
Ljavy17's Avatar
It erases the whole SKyline look alike thing. lol or even corvette look alike.
Old 05-31-2006 | 09:24 PM
Beck's Avatar
lol well im tinting the brake lights too :P not gonna stay like that
Old 05-31-2006 | 09:57 PM
tiny's Avatar
but it creates a sense if uniqueness
Old 06-02-2006 | 02:48 AM
Beck's Avatar
****update*****
K i tinted the brake lights and a ****** bug landed in them and fucked the whole thing up. I went to home depot, bought some lacquer thinner and applied it to the tinted brake lights with a rag and the tint came off easily.
Here's a pic of both lights tinted and me in reverse
the light still shines through and mine were freakin dark. However i left the 3rd brake light untinted for safety reasons
Here's the lacquer thinner i used and the outcome of the tail lights after detinting. They look good as new (and my in-n-out cup ):
and here's a random shot of the stingray vette 25th anniversary indy 500 pace car sittin in my garage:
Old 06-02-2006 | 02:57 AM
Rangerondubz's Avatar
Good write-up man will def be doing this within the next couple of weeks
Old 06-02-2006 | 03:07 AM
robby_06_cobalt's Avatar
what would be involed in doing to front lights, will the cops get mad...
Old 06-02-2006 | 03:14 AM
Beck's Avatar
I was thinking about tinting some eyelids onto my front lights, but im still not sure
Old 06-02-2006 | 05:22 AM
Kemble's Avatar
Black vinyl the front headlights instead of painting them. This way its not permanent.
Old 06-02-2006 | 05:23 AM
Beck's Avatar
the tint spray is easily removed with lacquer thinner
Old 06-08-2006 | 05:53 AM
Beck's Avatar
Bump... added some more pics to original post
