Appearance: How To: Ultimate High Beams for Projectors
Thoughts and opinions on tapping into the highbeam wire to also power the HID low beams rather than taking it directly from the battery? So (just to be clear), the highbeam wire would be supplying 12V to the highbeam bulbs, the HID ballast, and powering the relay when you flick on the highbeams.
I've actually done what I've described, on my girlfriend's 2002 Civic when we replaced her headlights, and we haven't had any trouble with blown fuses, melted wires or overheated wires, etc. So I was contemplating doing it now with my TC. But I would rather try to work it into the fuse panel, or make it a bit tidier, if I was going to run it off the battery, and try to hide the wires a bit better. I think it would be safer to run it off the battery (with a 30A fuse of course), but by tapping into the highbeam wire, you can hide all the wires and relays inside the bumper, with no worries about trying to secure any wires running from the headlights to the battery...and then ontop of this, I'd also like to do the same type of thing with the foglights...because the fog lights also turn off when you turn on the highbeams...What have other's done for this?
Better yet, does anyone know the mmaximum current that a 55W halogen H7 bulb will draw? And the maximum current that a 35W DDM Slim HID Ballast will draw?
ps. when I refer to the battery, i'm not talking abuot the actual battery in the trunk, I mean the terminals by the fusebox...sorry should've mentioned this before....
well the main problem is hids require more power to start up. once running they are by far more efficient over halogen. and unfortunately i don't think there's a cookie cutter answer for how much they actually draw seeing as different hids and different ballasts will act differently.
If your plan is to use the stock wiring for whatever reason that's fine. just get a plug and play harness. just know that if you do so then you may run into issues in the future. Some people have done plug and play for years and had no problems and others it gets a melting in a month.
regarding the highbeams and foglights the question is do you want the foglights on every time you have on your highbeams or do you still want to be able to turn them off? it would be easy to wire the highbeams in with the foglights so they turn on every time you hit the highs and are "controllable" when you have the lows on. but making it so you have control all the time and they turn on with the high beam would require you to run completely new wiring
these are general numbers, but show why 12V and 55w arent always the case. the ballast creates more than the 12V provides.
1. Ignition. HID lamps need an appropriate voltage across the electrodes to initiate and mantain glow discharge. Furthermore the ballast should provide sufficient current at glow discharge voltage(appr. 90V for HPS and 180V for MH) forcing the glow-to-arc transition. Therefore, the ballast should provide increased open circuit voltage (>600V) for MH(Type I, 2+1 electrodes) lamps and high voltage pulses (2000 - 3000V, 1µs) for MH (Type II, 2 electrodes) and HPS(2 electrodes) lamps.
The ballast increases voltage, but you're still drawing 55 watts of power (assuming a 55W ballast), any extra power is drawn from a capacitor which has been precharged from the last time the ballasts were on and powered up fully.
You probably could but that sounds like a major risk of setting the car on fire. Relays are used to safely switch high voltage high current loads from one source to another. They should most definitely be used in something like this for safety.
#38
Actually they're used to switch current on/off using another voltage source... Stop confusing the guy
#39
That's what I said.. One source to another. High voltage/current from battery to HID ballasts in this example. One source to another. Uses a low voltage source to signal the relay.
#40
Ugh no you said "Relays are used to safely switch high voltage high current loads from one source to another"...
They don't transfer anything, they just switch power on and off...
#43
If you want redundancy I guess you could hook the positive side of both factory headlight wires to the signal side of your relay, but one will do just fine. I just used the drivers side because that's the side I have my relay on and then I don't have to run a wire across. You would have to do this method though if you had one of those Dodge vehicles that turn off the headlight when the signal light comes on, because you don't want to put that kind of stress of turning on and off on your bulbs.
#46
ok so i splice into both headlights and run the two wires into one to go into the relay right?
#48
#49
Well if you want both high and low you're going to have to hook into all four wires.
I would suggest one relay run the high beam and one relay run the low beams though, since they're rated at 30Amps each and each headlight is fused for 10 amps each. You could get away with just one, but just to stay in factory specs, I'd use two.
#50
I would like to know how to wire it so the high beams turn the fog lights on as well, while keeping functionality during low beams... Is it just run a wire from the positive on the fog lights them self to the spot where the high beams or sending power to the low beams, or is there a better set up?
Another thing is, will the high beam circuit be able to hold the power load of the high beams, low beams, and the fog lights?
