Appearance: How To: Ultimate High Beams for Projectors
Old 04-11-2018 | 07:04 AM
  #76
63 Nova SS's Avatar
Do you have a light out in the 1st pic? 2nd pic doesn't look like all 4 are on because the light output is far away from the car like when you only run brights?
Old 04-13-2018 | 03:13 AM
  #77
ghostmechanic's Avatar
Nope. No light out. And the 2nd pic is all 4. I dunno why it looks like it does in the pic. It's pretty impressive driving. Though I do now have a weird shadow just past the right low beam for some reason. I had swapped in LED bulbs for my low beams for a while because I wanted to try them since they're instant on. When I swapped back to the HIDs & had to readjust them, this weird narrow shadow showed up. I also have an odd glob of light I call a ghost light that shows above the low beams against my garage when I pull up to it. That was never there before either. I'm kinda thinking I have a defective bulb.
Old 08-27-2019 | 08:59 AM
  #78
AG305's Avatar
gotta bring this back from the dead because im currently doing this as we speak. my question is, what size fuse should i use for the wire that runs from the battery to the relay?
also, will any 12v relay work? i bought a pair off amazon that are 12v 40a and have 4 pins. 85, 86, 87 and 30.
thanks!
06Pursuit
01-26-2011 04:46 PM
tpete763
03-25-2010 03:18 PM
matfud04
03-23-2008 09:08 PM
VeNoM0713
07-14-2007 03:16 AM
