Interior: How to upgrade the stock Pioneer sub to sound awesome and look stock. (With Pics)
Old 04-12-2015 | 09:27 PM
  #151
SS_2009_TC's Avatar
I will go with the 4ohms setup
Old 04-13-2015 | 09:28 AM
  #152
I loved my setup before selling it because weight reduction. Lol.
Polk audio MM1040 was perfect, . had to trim the insides of the box for it to fit but after that it was drill new holes and seal! Had it wire. to a 300w alpine amp and le. it bang. Too bad i didnt listen to too much music though, the blower and enxhaust is all i need lol.
Old 01-10-2016 | 10:13 PM
  #153
tamadrummer's Avatar
I'm having some issues making my amp work. I bought a line out converter and hooked it up to the wires that go to the stock sub but I'm getting no sound! Wondering if the amp is bad, but I've also never had to use a line out converter before either. Ideas?
Old 01-10-2016 | 10:15 PM
  #154
Originally Posted by Black08SportCoupe
Instead of doing anything with the stock system ill leave it how it is, but I need to be able to have a signal from the stock headunit. Won't I need an adapter to get a signal to the amplifier? Does anyone know what the name of the adapter would be? Using rca audio cables to a mono amplifier.
It's called a line out adapter.
Old 07-22-2016 | 12:06 AM
  #155
Shanman's Avatar
I am having power interruption when connecting my wires from my sub to my amp? I have connected my 2 ohm sub to pos and neg on the stock red/black wire connector and then to pos and neg on the amp. It wont work when I bridge it either. I get some sound and then the amp cuts off after several seconds and then powers back up and then repeats. Does the stock connector output a DC voltage? My amp has a protection feature if it senses DC...
Old 07-25-2016 | 12:33 AM
  #156
Shanman's Avatar
Originally Posted by SWmaster
The last thing you need to do is make an adapter cable for hooking your stock sub output to the high level input of the amp. Just follow the wiring diagram for the amp and hook the positive and negative for the left and right up to their counterparts on the stock connector you took out of the box. Don't worry about what is left or right, just make sure positive and negative are correct for each pair. I used 16 gauge speaker wire and end to end crimp connectors to make a five foot cable. I put the wires in a flex tube and taped it's entire length with black electrical tape.
Should I use a line out converter with my aftermarket HU or should I get a high level to low level RCA adapter. My subwoofer will not work when plugging my rca strait from the back of my aftermarket HU to the amp. Also using the old signal wire that went to the sub seems to not be a good idea from what the guys at the audio shop told me. They were telling me to get the signal before the amp???
Old 07-25-2016 | 09:08 AM
  #157
EmperorJJ1's Avatar
what are you trying to do. and what do you have?
Old 07-25-2016 | 10:17 AM
  #158
Shanman's Avatar
Pioneer gps HU powering GM-A6604 amplifier with kicker cvt-10 sub in stock enclosure Trying to take signal from stock wiring to stock sub and use it for signal for kicker, bc low level inputs do nothing for bass.
Old 07-25-2016 | 10:50 AM
  #159
EmperorJJ1's Avatar
lol im trying not to talk **** but wow... ignore that
what impedance (ohm) is the sub?
Old 07-25-2016 | 02:28 PM
  #160
Shanman's Avatar
2 ohm sub,if my setup is stupid, I'm not audio intelligent, just using what I got at a decent deal.
Old 07-26-2016 | 01:42 AM
  #161
EmperorJJ1's Avatar
its not stupid, its just doesnt make sense....
ok so the problem is your amp is a 4 channel which is meant for 4 speakers and your sub is 2 ohm which is meant for a mono amp.
The only way the amp runs stable with that sub is on one channel in which case you get 60w rms which is probably as much if not less than the stock amp/stock sub
also running an LOC at the stock sub means you have a HU powering an amp that would then be converting the signal for the new amp. it works but really you should be running RCA to the HU instead of having the signal go through 3 different things
Old 07-27-2016 | 02:44 AM
  #162
Shanman's Avatar
hmmm, well dam, had to do a little research, so either a monoblock or 2 channel. I think the GM-5500T would be a good match for my kicker. The GM D8601 seems like overkill. Does this seem to match up a bit better? Or is the amp underpowered in this setup as well?
Turbo Johnny
02-21-2019 10:41 AM
The Rookie24
01-20-2016 06:14 PM
chefhhr
10-26-2015 11:36 PM
camaromanss1992
10-01-2015 11:51 PM
dieGone
09-23-2015 11:20 AM
