2.0 LNF Engine: How To: Valve Gunk/Coking Removal
Old 07-19-2015 | 11:43 PM
  #201
Powell Race Parts's Avatar
FYI I am testing the inevitable v.3 seperator that pulls the blow by, previously returned through to the inlet manifold, directly to the seperator, so the off boost vacuum pathway to the inlet manifold is eliminated. So is the internal check valve, so no chance of failure in that regard. Should be testing it next week. Its sort of a slam dunk, I have one Kappa running around for a year already with the mod ...life is good
to clarify: the blowby gasses are directed out of the rocker cover via the rocker cover port, to the turbo inlet, and also through the inlet manifold plenum. The blowby gasses that are directed to the plenum come up from the block, through a passage in the head, to the rocker cover mezannine; along two biscuit seperators, and then back down the head to the inlet manifold port, where a pc valve permits "seperated" gasses into the inlet manifold plenum to be returned to the engine in combustion. The theory all goes to heck when the pcv valve sticks, or the biscuit seperators cant deal with the oil. Which is often.
so. we remove the pcv valve, and block the entry to the plenum ,and take the gasses out of the top of the inlet manifold to the seperator.
simple really
Old 08-31-2015 | 03:56 PM
  #202
stenguyen1's Avatar
I wanted to provide some insight, as i have just finished doing this over the weekend.
This only took me and a friend 4 hours to get done. basically an hour per cyclinder.
1. Make sure you have everything covered in the engine bay and around as this stuff does get everywhere.
2. Have a well operated shop vac with a narrow attachment, i used my normal vacuum attachment to get in the small areas of the valves.
3. Purchase a blast gun that does not have a hopper or bag on the actual gun, this will make you get annoyed as there is not much room to move the gun around and you have to keep refilling the gun up.
I bought this one from harbor freight for 30 bucks. It basically has a container to hold all the media and a line from the bottom of the container with a long hose to connect to the gun to allow you to move back and forth easier. Also no refilling time just blast away.
4. Try to get some picks or tiny flat screw drivers to scrap away the gunk behind the valves, and in and around the valves, it good to try to scrap some of the gunk off before blasting it with the shells so you don't have to do lots of blasting.
5. take your time masking off everything, as the prep work is what will make this job a clean one or a messy one.
6. Make sure you don't blast long burst, as media will just collect in the cylinder.
7. While you blast you can put the vacuum in the cyclinder at the same time to suck up all the media while blasting. (small attachment comes in handy here).
8. enjoy blasting as this is fun part.
here is my results after 85k miles. I bought the car with 80k miles.
exninja (08-31-2015)
Old 02-15-2016 | 03:54 PM
  #203
TotalChaos's Avatar
I believe I need to do this soon. I am at 63k. What PSI should be run from the compressor? The OP said 110. Is this a good PSI? It seems to work for him.
Old 02-15-2016 | 06:07 PM
  #204
Depends on what the material gun calls for, some max around 90-100psi. Just make sure you wear ear plugs, makes stupid high pitched loud sound when you go over an edge or are working in the port randomly.
Old 02-21-2016 | 04:55 PM
  #205
SlowBaltSS07's Avatar
Anybody do one of these on the supercharged engine?
Old 02-21-2016 | 08:33 PM
  #206
umrdyldo's Avatar
Should not be needed because of the port injection. If it were an issue the cleaning would be the same mostly
Old 02-21-2016 | 09:55 PM
  #207
They can still get bad, just takes more and normally a failed or failing pcv
Old 08-17-2016 | 12:03 AM
  #208
Scypheroth's Avatar
QUESTION: my engine has 67000miles on it and i was wondering what i can do to prevent this from happening to my low miles engine?
Old 08-17-2016 | 12:10 AM
  #209
umrdyldo's Avatar
Your engine is not low miles in regards to valve coking on the LNF. At 75k miles my car needed it bad. Yours probably does too.
Old 08-17-2016 | 12:21 AM
  #210
Scypheroth's Avatar
k then what can i do to stop it from getting worse? i dont feel safe throwing anything in my cylinder head no matter who tells me its safe...just would liek to prolong this engine as far as i can before i need to drop in a new one...
P.S in canada (where im from) under 200.000kms is considered low kms and under 100,000 is brand new...my car has 109.000kms
Old 08-17-2016 | 12:29 AM
  #211
Scypheroth's Avatar
Old 08-17-2016 | 08:58 AM
  #212
umrdyldo's Avatar
Powell oil separator is it.
I understand your concern about cleaning the valves. It's not for everyone. I'm dreading doing it again
Old 08-26-2016 | 12:21 AM
  #213
Baznight's Avatar
Awesome post on how too clean carbon-buildup. The oil separator seems like a great idea. I just purchased a 09 ss/tc and was researching known issues. I was wondering if anyone has tried meth injection to reduce buildup?
Old 08-26-2016 | 08:32 AM
  #214
Staged07SS's Avatar
Administrator
Administrator
Sub'd for my GS.
Old 08-26-2016 | 10:22 AM
  #215
hawkssoccer11's Avatar
its just walnuts. gm would do the same thing if you asked them. and you clean the valves so as soon as the car is started it is all burned off because its just walnut shavings. not gonna hurt anything.
Old 09-16-2016 | 01:14 AM
  #216
cobaltssdude420's Avatar
Is there anything VERY IMPORTANT i should know about this process before doing it? I understand that the valves need to be closed, things need to be covered and taped off and to take my time. I just don't want to **** anything up
Old 09-16-2016 | 11:44 AM
  #217
here you go man this should help with all your questions/concerns lol
https://www.cobaltss.net/forums/how-...emoval-304188/
ECaulk (09-16-2016)
Old 09-16-2016 | 12:29 PM
  #218
exninja's Avatar
LOL was this sarcasm?
Old 09-16-2016 | 12:50 PM
  #219
Old 09-16-2016 | 01:23 PM
  #220
why????
Old 09-16-2016 | 01:26 PM
  #221
exninja's Avatar
You linked the same thread we're in
Old 09-16-2016 | 01:51 PM
  #222
oh jesus effing christ!!! i thought it was the one page rudy from FMSR started years ago my bad guys
Old 09-16-2016 | 02:08 PM
  #223
exninja's Avatar
Old 09-16-2016 | 02:19 PM
  #224
saw it when exninja mentioned it
Old 09-16-2016 | 04:56 PM
  #225
hey atleast i gave everybody a good laugh lmfao
exninja (09-16-2016)
