2.0 LSJ Engine: Install Powell F35 Stage2 Mounts
#53
Sorry to bump an older thread. I just did these tonight what kind of vibrations are there. I only feel vibration at idle any other time its fine. I didn't do much of a "short drive" I went up and down the driveway at my parents and also went in reverse everything was "loose" torqued to specs.
I did notice my engine mount bolts didn't line back up but I am not driving this car to far. So far the mounts seem worth it. Also after everything I drove it for half an hour and the CEL came on(no idea on code until I get scanned tomorrow) This wouldn't have to do with those engine mount bolts would it? Everything ran fine the entire time, nothing changed or felt wrong.
#55
your intake piping probably separated alittle bit and your probably throwing a code for the maf sensor. This happened to me from jacking up the engine to get the rear mount's bolt through the hole. Check you piping, re-tighten the clamp then clear the code...a$$uming this is your problem.
#58
USA Y U NO HAVE AUTOBAHN?
Fair warning
These instructions should have a BOLD PRINT saying DON'T FORGET TO PUT YOUR SPACERS IN
I was following the step by step instructions and it doesn't say anything about the spacers, I guess it was assumed. I forgot I even had the spacers to begin with.
The front trans mount bent the metal bracket, and I can't bend it back out.. So no spacers there and it seems to hold OK.
This is the aftermath of tightening the rear trans mount down with no spacers
#61
The front transmission mount bracket just bent and I couldn't un-bend it to put the spacers back in> i'm sure it's okay the way it is.. I hope..
I have to drive to work and back the next few days. .. Should be okay without the rear tran mount if I take it easy ?
#63
I'm too JDM for you
Fair warning
[img]http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/296436_10150361132020662_567685661_8480206_1247691 319_n.jpg[img]
#73
No.. No one will express or anything..
I drove it 2 miles today
I'm so nervous to drive..
It's a PITA!
It feels solid.. And i took it really REALLY easy when I did drive it. The front mount is on their good
and the mounts are fine
I just need the rear bracket.
It's a PITA!
