2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
#451
It wasn't all that bad to get out actually, the hardest part was finding the clip to get that undone. I found that once it was loose, all I had to do was push it down as far as it would go into the bumper, and then there was enough room to rotate it so it came out pretty easy.
Like you said, doesn't seem to have done much, but if I ever get a CAI I guess I saved some work.
That's where it'd be.
This is where the bolt was. I wasn't able to get a picture of the clip unfortunately :\
#453
You must have really done it wrong then.
A) correct, there will be no power increase
B) incorrect. There is a HUGE sound increase. The resonator is no longer filtering out the low frequency it was meant to, and therefore it is ABSOLUTELY present.
C) incorrect, unless you often drive through lakes or ford rivers. The airbox's intake is at the top of the fender, it's not likely to get anything more in it by removing the intake resonator.
It was the first mod that I did when I bought the car, and it sounded much louder at WOT.
#456
Just took the silencer out of my 2007 Pontiac G5. Yes, there is a difference in sound, at least from inside of the car. I also noticed a bit better throttle response. This should not shorten the life of your air filter in any way... there is no prefilter or anything inside of the silencer to prevent crap from reaching your air filter.
Had to remove several bolts under the bumper and the wheel well to get enough room to get the underside screw out and release the pin. No big deal. I'd say it took all of fifteen minutes.
