2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Old 05-15-2008, 04:07 PM
  #151
umrdyldo's Avatar
I can't brake those clips.
Old 05-16-2008, 05:02 PM
  #152
tru2nrtt777's Avatar
Originally Posted by XgunsmokeX
ummm its for the SAI, u might wanna put a filter on it
It isnt SAI the only hose I have on that side of the throttle body is the PCV hose which if it isnt connected it wont pass inspection and it will dirty the oil since there is no vaccum to pull out the fumes. I have a 06, not a 06.5 What I was refering to was the bottom of the air box just below the filter where you have a tube going to the back of the headlight. The only heat source it has is the radiator/trans cooler which is not in the direct path of cold air.
Old 05-20-2008, 07:42 PM
  #153
BlackMachine's Avatar
very nice mod!! i just did it...one thing thou...getting that silencer out is a bitch...i ended up takeing my wheel off and pulled threw the wheel well....sooo gay but it was worth my time...lol
it makes the car sound deeper...and there is deff. more pull on it!!!
thankx for the how too...
there is one that u must pop off...just muscle that **** man
Originally Posted by kingmike06
Omg, I just finished removing mine. It was really hard. for starters its a screw thats under the silencer and and bolt that has to be pull out thats behind the silencer and below the intake filter. It was a pain tring to remove the screws and then tring to remove the silencer without out removing the bumper is hard. You have to take the top part off and then twist and bend the wheel base and bumper.
x34235234524352435 lol
i forgot to say...removeing your passenger wheel is the best deal.
it came right out threw the wheel well after i took one screw out...
Last edited by BlackMachine; 05-20-2008 at 07:43 PM. Reason: Automerged Doublepost
Old 05-21-2008, 02:40 AM
  #154
Charba951's Avatar
does any of your guys engine rev a little higher than normal when you start up now that you did the mod?
Old 05-21-2008, 08:54 AM
  #155
LScoupeTUNER's Avatar
its should...also you'll notice much better throtle response...
Old 05-21-2008, 06:17 PM
  #156
Charba951's Avatar
Ok, cool I just wasn't sure. How high does your guys engine rev up to when you start up? Mine goes straight to 1100 RPM.
Old 05-23-2008, 06:33 PM
  #157
alleged's Avatar
this thing took me on our to take out but i like the results!!!
Old 05-24-2008, 06:07 PM
  #158
midniteracr06's Avatar
i did this a few months ago and took out the stock air filter in the box. put a flex hose on the end of the airbox that goes into the wheel well and on the other end just put a spectre high flow filter on it. sounds pretty beast for say 30 bucks? as far as gas mileage goes...well, i like hearing her purr when i get around 3grand so my gas mileage is always near 28 around town. but if i take it really easy..i got 40.6 mpg when i went to my gf's house which is 110 miles away. i was impressed. hope everyone likes this mod as much as i do =)
Old 05-27-2008, 07:54 PM
  #159
martz.w's Avatar
some people in the past have claimed that this mod helps gas mileage, I think we could all use a little help there. Has anybody noticed this and if so how much of a change? thanks
Old 05-28-2008, 09:53 PM
  #160
elbeno600's Avatar
okay so im stuck on someting holding it down by the wheel well it looks like a plastic clip in thing with foam around it how do it get that bitch off i mean ive pried on it pretty hard.. or is it an accual bolt? if so how do u remove it? cars kinda torn half apart so if some one who has done this mod could reply some time soon that would be great
Old 05-28-2008, 10:21 PM
  #161
Red07SSNA's Avatar
If it is the mount towards the front of the car (back mount is a plastic retainer) then it is a 10 MM bolt.
Old 05-28-2008, 10:24 PM
  #162
boostedss26's Avatar
just did this to my wifes car the other day. It's a plastic clip just break the bitch
Old 06-10-2008, 11:43 AM
  #163
ilovecars's Avatar
man i just did it today and its sweet it sounds good! and its undetctable by my parents cuz when there in the car ill drive below 3 k i think i have a sleeper build in mind but yea going through the wheel well was easy as **** just a bunch of push screws and bolt/screw things but yea it wasent hard at all and the resanator thing came out with no problems idk what every one was bitching about
edit- and the plastic thing is a push screw just lift up on the middel part and then pop the whole thing out
Old 06-16-2008, 03:31 PM
  #164
USAF1123's Avatar
just did it today. sounds nice with my catback. only thing is i would mention in the intructions that you may have to take off part of the inner wheel well panel to get at the silencer's screw.
Old 06-17-2008, 07:07 AM
  #165
JayB1127's Avatar
Wow.....I just did this, took about an hour and a half, 45mins to take it out and reassemble......45min joyride showing off the new sound. WOW, what a difference in sound, the mtor is so much louder now.....and response is so much better, between 3k and 4k RPMs is its sweet spot, GREAT MOD a suggestion for all........
NOTE!!!!
There is two screws holding the silencer One is a 10mm Bolt......the other is a plastic push thingy, Ill yank on it for 15mins trying to break it with no luck, Then I took 3 screws outta the wheel well, poped it back so I could see and pulled it out with a pair of pliers, under 5 mins, VERY EASY MOD LEVEL 1!!!!!
Jay B
Old 06-26-2008, 10:08 PM
  #166
falconreplt's Avatar
i tried to take the "thing" off, but i don't know which screw/bolts to take off to get the innerfender off. i know theres like 4 7mm's to take off, but where and which ones??
Old 06-26-2008, 10:11 PM
  #167
ilovecars's Avatar
its not that hard but pretty much every one inside the wheel well and then theres some twards the front and under. just follow the plastic and undo everthing to get the peice off then thats it
Old 07-06-2008, 09:48 PM
  #168
a mile a gallon, maybe less, before I got 24.5, now I get 25.9 and the milage guage hasnt been reset since around 10,000 miles.
Old 07-08-2008, 09:12 PM
  #169
va thunder's Avatar
just did this tonight.....i went at it the hard way at first, couldnt get it out so i then loosened the wheel well and popped out the pin and it slid right out. BIG difference in sound and the response seems a little sharper. This is my first mod to my new cobalt, so let the rest begin!
Old 07-14-2008, 02:30 AM
  #170
constantproject's Avatar
totally rocking this mod out tomarrow night when i get back from cedar point.
Old 07-14-2008, 02:33 AM
  #171
FASTL61's Avatar
its great IMO
Old 07-15-2008, 08:08 AM
  #172
Jplaya023's Avatar
any idea what pipe i can use to run it down to behind my fog light? blktrax mentioned a 3-1/2 Stainless Steel Truck Exhaust Stack Pipe but i have no idea what that even is. i searched for it and all you get is 18 wheeler exhaust stack pipes lol.
what type of pipe and where can i get one?
Old 07-16-2008, 04:56 PM
  #173
pattersonn247's Avatar
Wow this mod was so easy it sounds great and alot more throtle response i think only took about 30 minutes for me to even do
Old 07-17-2008, 11:20 PM
  #174
Jplaya023's Avatar
i actually went to autozone and picked up a universal intake hose and stuck one end into my GMPP chrome intake pipe and the other end below my headlight with the filter on it and its RIDICULOUS!
Old 07-18-2008, 02:39 PM
  #175
08slatecobalt's Avatar
Fairly easy to do...took me about 25 minutes. Took out the headlight and bracket and undid the inner fender liner. I did not have to take the front wheel off, though you do have to turn the car on and turn the wheel all the way to the right to get it. All in all it was a pretty easy mod. Thanks for the heads up.
Quick Reply: 2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
