2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
#205
All you need is a 10mm socket, a 10mm wrench (not nessecary, but very helpful), a 5/32" socket and/or wrench, a socket wrench (or driver), and some pliers. It's seriously so simple.
5/32" is for all the wheel tub bolts, 10mm is for everything else, and the pliers are for that stupid pin under the airbox. Door panel puller works way better in that area.
#208
I just finished my last night. It was kind of strange at first. But like a few of you said. That last bolt on the inner side of the wheel weld was giving me some issues. I finally was able to pull it off. The sound is rather nice. It's nothing that is very annoying or anything. It sounds like the AEM CAI I had on my EG6 back in the day.
#211
did mine a few weeks ago...its not that hard to pullit out of the light hole but you have to figure out how...i put on my ss/sc cat back and my car is waaay happier and sounds like sex, quiet room mate sex tho....now i just need header & dp and a new muffler
#212
#215
I doubt you'll see any mpg difference. I'm going to give it another try tomorrow at work.. we have a pile of air tools there I'll try to get that damn bolt off. I can't believe it's stripped.. It's bad enough I can't get it off without air.
#217
No, the one under the headlight - not the rubber thingy
This one:
Click for full size - Uploaded with plasq's Skitch
This one:
#221
The bolt itself. I pulled out the air ratchet today at work and did the job with a two inch extension, 6mm metric socket, and a 10mm metric socket. Took out the headlamp, and the rocker panel to get out the air resonator. Worth it though for having that hunk of plastic out of there.
That air ratchet really got it's workout today, it was hot after I was done with it in an hour of work!
