Exhaust: LNF: Installing Bad-Mab Catless downpipe
How to install a Bad-Mab catless dp or any dp really
Minimum tools required
15mm medium to deep socket
knuckle adapter
8"-12" long extension
ratchet or impact gun
7/8 or 22mm wrench (if you prefer a O2 sensor socket)
15mm box end wrench
Extra things to have
Penetrating spray oil (Wd-40, PB's, Liquid Wrench, ect)
Anti-seize
A Lift (makes life way easier)
If your cant see the pictures this how to is useless
First get the car in the air and spray the exhaust studs on the dp with penetrating spray oil
Using a 15mm medium or deep socket, knuckle adapter, ratchet/Impact, and a 8"-12" long extension remove the 4 for nuts from the studs on the turbo side of the dp. Then pull down the turbo side of dp onto the subframe
Drop the dp down and finish unscrewing the O2 sensor. Remove the old exhaust gaskets and install the new gaskets that came with the Bad-Mab dp. Also put a light amount of anti-seize on the exhaust studs threads if you want.
Put a light amount of anti-seize on the O2 sensor threads. Then screw the O2 sensor into the Bad-Mab dp. (I recommend that you install a O2 defouler which is necessary with most catless dp's unless you want a CEL in the near future)
Slide the new dp on the turbo exhaust studs first and then the back studs. Tighten the nuts evenly on all the studs.
Start the car, check for leaks and your done. Enjoy
Also I like how it helps the turbo spool faster and makes the turbo whistle louder. I'm sure you have noticed.
Bad-Mab builds a great down pipe and you cant beat it for the price.
I haven't seen how the Megan racing dp looks but I can say that this dp is show quality out of the box.
Mine had great clearance between the defouler and heat shield. Try pushing the heat shield towards the floor board. I have had to do this on a couple on of new cars from the factory having the similar issues. Hope this helps.
alright thanks man ordered this aswell
i got mine in my moms house waiting for me 2, i am not using a defouler though, i just had vince tune out my CEL for the DP but i can still read the 02 sensor on my Dashhawk
oh and also to kid above^
This CEL wont do anything to your car, it'll just tell you that you dont have a cat nothing big you get more power
because of no back pressure
Last edited by steven2008ss; 02-20-2011 at 12:34 PM. Reason: Automerged Doublepost
