How to requests and questions Please post your requests and questions for How to Guides.
Can you swap a 06 motor with a motor from an 08?
Old 05-06-2013 | 06:17 PM
Mike636's Avatar
I have a 2006 chevy cobalt 2.2L with a blown motor and a 2008 chevy cobalt 2.2l that is totaled is it possible to swap them? Only difference I can see are that the heads are different the one on the 08 has a cam sensor with coil packs, the 06 has an ignition module.T he 08 is an automatic and the 06 is a manual transmission so I don't think the computers will swap out. Is it possible to just swap out the coil packs and ignition module from the heads? It looks like they match up.
Old 10-24-2013 | 07:07 PM
Malicious intent's Avatar
U may need the PCM. And if it has a different cam sensor it may have a different firing order. I did a swap on a 96 eagle talon once. Put a newer engine in. Didn't need a PCM or anything but I had to swap the cam sensors and doing so actually changed my firing order. Took me forbear to get it started. Or course once it did I had been sold a 4g63 with bad crank bearings. Knock knock knock knock
05-28-2022 04:47 AM
Solaris99
28
03-15-2017 02:22 PM
ThoR294
10-04-2015 09:44 PM
Stuff
10-01-2015 06:47 PM
ThoR294
09-28-2015 06:31 PM
