help
help
My car wont go in to any gears when i push the clutch in it wont get anything i can go in a circle with my gear stick what piece is needed to fix this and what is the problem. I cant get no gears if car is off i was driving the car with no clutch one day and then all off a sudden i couldnt Get any gears
Originally Posted by bengee
Can u show me a picture of what its sopposed to look like or what im looking for
Not the bracket that circled but the two cables above it. Make sure they are still connected. Also remove your shift boot and make sure the cable clamp is still snapped onto the bottom of the shifter. These are the easiest things to check so you should check these first.
CudaJoe
40
08-16-2016 01:52 AM
