remove timing cover
remove timing cover
ive been searching around the how-to's and cant find anything on how to remove the timing cover. does anyone have a decent descriptive explanation of all the steps?
This may work i really didnt look at well
https://www.cobaltss.net/forums/how-...sioner-276244/
There is an engine section that explains how to remove the timing cover (front engine
cover). It's fairly complex.
As I remember, the total cost is about $150.00.
its much easier than it looks.
support the engine with a jack and a board of wood (or some sort of cushion)
remove the upper engine mount (and everything else in the way like the intake, etc)
you also have to remove your passenger side tire.
remove the serpentine belt and tensioner
there should be about 9-13 10mm bolts holding it in.
remove the crank pulley
and the case should be able to be removed now.
if i had more time id go into further detail, but this is it in a nutshell.
youre going to get dirty too.
lol this was exactly what i told him pretty much when we spoke yestarday
i wasent sure if 10mm or 13mm bolts and how many there were
royce777
09-28-2015 08:11 AM
